    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Help for backup :S i not understend it!!!
vincenzot
Regular Pleskian
Good Mirning,
i have update my plesk from 8.6 to 9.2.3 but i not have understend the procedure for backup from ssh
I haved use this command
/usr/local/psa/bin/pleskbackup -z -server --output-file=/disk1/$filename.bkp
Is correct?
So how I can restore the backup from shell?
The .bkp exenctions is correct or i must set tgz or xml?
In the plesk 8.6 usually i use backup-unpack I can make this operation with plesk 9.2.3 ? How i can?
I wait your answer
Regards
ok
i must make the backup in this mode
/usr/local/psa/bin/pleskbackup -z -server --output-file=/disk1/$filename.tar ?
And for unpack the backup how I can i haved tryed backup-unpack extract but it not work...where I wrong?
I wait your answer
Regards
Yes, you are correct. For restoring backup you should use /usr/local/psa/bin/pleskrestore utility.
Ok,
but if i want restore only 1 domains? How I can ...? i have tryed with level domains -filter:domain.tld but it seems not work...
Where i wrong?
Which sort of errors there for this restoring? Can you provide these errors?
