Help me with commtouch after removing Plesk.
Status
Not open for further replies.
BorjaB
Hi all.
I'm playing in my localhost with a mirror of my web, and I decided to try a Control Panel.
After that and decided to remove it, I use this script for do it http://kb.parallels.com/es/112988
After that, I see that my apache is dead, so i begin to reinstall it and... surprise. And here is the BIG problem:
Commtouch packet depends plesk-core, but it cant not install it.
Code:
commtouch : Depende: plesk-core (>= 11.5.30) pero no es instalable
Things I've tried:
1) apt-get autoremove, apt-get install -f , apt-get purge, (nothing with apt-get worked for me). Looking for commtouch (whereis commtouch, which ... I didn't found anything. Google has no info about that. What the hell is commtouch? Seems to connect to mysql, but I have no idea...)
2) I've tried to connect to my SQL and create whatever commtouch needs, but I can't connect, I don't know why! Seems user and password problem. Yesterday I could connect ok.
3) I've tried to reinstall plesk. But installation script run an apt-get update and, here is another problem, because it detects a problem with commtouch dependency and stops the installation.
I can't install/upgrade/remove anything.
If I can't solve it I should reinstall the operating system. It's crazy!
Please, any light in my way? Thank you.
Code:
baldruus $ sudo apt-get install -f
Leyendo lista de paquetes... Hecho
Creando rbol de dependencias
Leyendo la informacin de estado... Hecho
Corrigiendo dependencias... Listo
Los siguientes paquetes se ELIMINARN:
  commtouch
0 actualizados, 0 se instalarn, 1 para eliminar y 0 no actualizados.
Se liberarn 12,3 MB despus de esta operacin.
Desea continuar [S/n]? s
(Leyendo la base de datos ... 266123 ficheros o directorios instalados actualmente.)
Desinstalando commtouch ...
ctmilter is not running
dpkg action:
 Trying to start service mysql... /usr/sbin/mysqld (pid 24798) is running...
done
 Trying to establish test connection... connected
done
ERROR 1049 (42000): Unknown database 'psa'
ERROR while trying to execute SQL query, the query was: DELETE FROM `Modules` WHERE name = 'commtouch'
Check the error reason(see log file: /tmp/plesk_11.5.30_installation.log), fix and try again
dpkg action:
done
done
***** installing problem report *****
dpkg: error al procesar commtouch (--remove):
 el subproceso instalado el script pre-removal devolvi el cdigo de salida de error 1
Se encontraron errores al procesar:
 commtouch
E: Sub-process /usr/bin/dpkg returned an error code (1)
Solved
After a couple of hours finally i've found the solution, I post it here because maybe it could help to someone.
Everything with root, it's faster.
With apt-cache show commtouch I can see more about the problem.
Go to /var/lib/dpkg
In every file you can see a duplicate-old. It's a backup file. Make an ls -la and you can see the modification time.
I made a backup of the original files, and copied *-old to the originals.
If the problem remains because you didnt install plesk correctly first time (like me) you should edit status file: nano /var/lib/dpkg/status
ctrl + W = commtouch and voil
Instead of removing it completely, first I removed the first dependency (plesk-core) but after "apt-get remove commtouch" stills tries to connect to mysql. So i though to remove the mysql dependency.
AND THAT'S ALL!!!!
Now with an script i've found http://amigolinux.foroes.org/t1-ubucleaner, for cleaning my computer.
I think I have job removing trash and files of the installation, but the havey is done.
And very sorry for my english, I know it's not good and I could use a translator, but I have no time. I spent all the day with this h...y s..t hehehe
Hi all.
Code:
Things I've tried:
Code:
  commtouch
dpkg action:
done
done
dpkg action:
done
done
 commtouch
Status
