• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Help move users
O
oscarlcs
Hello, like they move users or domains of a server with windows 2003 server standar and plesk 7.5.4 to another with windows 2003 server standar and plesk 7.5.6, note: the ip addresses are different and the clients also
Actually you should use backup/restore method to perform such a task. Backup domains at source server, move backup to target server and then restore it there. You will be prompted with mapping ip addresses so you will be able to map moved domains to new ip.
youshould firts migrate your initial server from 754 to 756, , also install the update and the last patch for 756, it will solve some bugs
then bacup, transfer the backu p fies on the ne server and then simply restore
it will ask you for mapping to the new IP
Actually the best way to do this would be using Plesk's Migration tool.
It has been introduced only in Plesk 7.5.6 and can only migrate stuff between 7.5.6 server, so you'd have to upgrade the source server (which you said it's still 7.5.4 to 7.5.6).
Also note that the migration tool needs to be installed separately. You can download it from:
ftp://download1.swsoft.com/Plesk/Plesk7.5/Windows/7.5.6/PMM/
For details regarding the migration tool and it's usage plese check:
ftp://download1.swsoft.com/Plesk/Plesk7.5/Windows/7.5.6/PMM/pmm_build051125.14.txt
P.S.
Don't worry about it... migrations are not that difficult.
