How often does application vault update products ?
T
tobtob
How often do the application in the application vault update ? For example, when will the Mambo application install version 4.5.2 rather than 4.5.1 . Or when will newer versions of phpBB be available.
Thanks,
Tom
Application Vault is packaged with Plesk releases, so you can *expect* new packages in every Plesk iteration/upgrade.
