How to connect nginx to work with a directory "web_users"?
Evgeny_Maltsev
Hi.
How to connect nginx to work with directory web_users for some virtual host?
This directory contains two accounts (user1, user2) with a large amount of static content (files .jpg), the downloaded web users themselves. At the moment they are processed by Apache, which causes an additional load on the server.
In hosting configuration for virtual host "domain.tld" set:
document root: httpdocs. (That is, the "httpdocs" and "web_users" directories are on the same level).
In the web server configuration settings (in additional nginx directives) i can't use the directive "server" (refuses to save), where you can specify the location of the additional "document root" for nginx.
Help, please.
Have you tried add needed custom directives to the following file /var/www/vhosts/system/<domain_name>/conf/vhost_nginx.conf manually?
Do not forget to reconfigure vhosts after that with
# /usr/local/psa/admin/sbin/httpdmng --reconfigure-domain <domain_name>
I tried in web server configuration settings (in additional nginx directives), all with negative result:
1. vhost_nginx.conf:
location ~ ^/\~user1/pub/(.+\.(ac3|avi|bmp|bz2|css|cue|dat|doc|docx|dts|exe|flv|gif|gz|htm|html|ico|img|iso|jpeg|jpg|js|mkv|mp3|mp4|mpeg|mpg|ogg|pdf|png|ppt|pptx|qt|rar|rm|swf|tar|tgz|txt|wav|xls|xlsx|zip))$ {
alias /var/www/vhosts/domain.tld/web_users/user1/$1;
# /usr/local/psa/admin/sbin/httpdmng --reconfigure-domain domain.tld
2. vhost_nginx.conf:
location ~ ^/~user1/pub/(.+\.(ac3|avi|bmp|bz2|css|cue|dat|doc|docx|dts|exe|flv|gif|gz|htm|html|ico|img|iso|jpeg|jpg|js|mkv|mp3|mp4|mpeg|mpg|ogg|pdf|png|ppt|pptx|qt|rar|rm|swf|tar|tgz|txt|wav|xls|xlsx|zip))$ {
This "locations" added in vhost_nginx.conf, but include of /var/www/vhosts/system/domain.tld/conf/vhost_nginx.conf in file nginx_ip_default.conf in section "server" follows the directive
location ~ ^/(.*\.(ac3|avi|bmp|bz2|css|cue|dat|doc|docx|dts|exe|flv|gif|gz|htm|html|ico|img|iso|jpeg|jpg|js|mkv|mp3|mp4|mpeg|mpg|ogg|pdf|png|ppt|pptx|qt|rar|rm|swf|tar|tgz|txt|wav|xls|xlsx|zip))$ {
try_files $uri @fallback;
Here is section "server" from nginx_ip_default.conf (relevant to the issue directives):
server {
listen 1.1.1.1:80 default_server;
server_name domain.tld;
server_name www.domain.tld;
root "/var/www/vhosts/domain.tld/httpdocs";
if ($host ~* ^domain.tld$) {
rewrite ^(.*)$ http://www.domain.tld$1 permanent;
location / {
proxy_pass http://1.1.1.1:7080;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
access_log off;
location @fallback {
access_log off;
include "/var/www/vhosts/system/domain.tld/conf/vhost_nginx.conf";
What is my mistake?
I try more without result:
location /~user1/pub/ {
alias /var/www/vhosts/domain.tld/web_users/user1/;
location /\~user1/pub/ {
Any ideas?
