Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Halloween is coming! To celebrate the occasion, we dusted off a couple of old skins, and even created a brand new one (Pixel).
The new Python extension is now available. It allows customers to deploy and manage WSGI-based Python applications on their websites directly from Plesk.
The Plesk Mobile apps for iOS and Android and the Plesk Mobile Center extension have been deprecated, and are no longer available for new installations. In Plesk Obsidian 18.0.84, the Plesk Mobile Center extension will be removed from servers during the upgrade, and the Plesk Mobile apps will lose their server management features.
The Social Login extension has been deprecated and will be removed in Plesk Obsidian 18.0.84. After that, it will no longer be possible to log in to Plesk with a Google, Facebook, GitHub account, or with a passkey. Plesk usernames and passwords, as well as logging in with a WebPros Account, are not affected.
Take a look in /usr/src/redhat/BUILD, I will bet you that the directory in there is not called "frontpage-5.0". What you'll have to do is modify the %setup line in the .spec file and change it to:
mmmh onestly im must say i don´t now....it´s a fresh centos-5 install with plesk.....nothing more
can you tell me how can i fix that or what to do?
Thats a tough one, If I were to guess I'd say either its using the wrong axps, or the code itself is not compatible with the version of apr you are using.
Did you try editing /etc/httpd/conf.d/mod_frontpage.conf and change:
LoadModule frontpage_module modules/mod_frontpage.so
to
LoadModule frontpage_module /usr/lib/httpd/modules/mod_frontpage.so
Maybe you also need to install the original frontpage-5.0-72psa.centos4.2.i586.rpm first for mod_frontpage.so to exist in that location... and then afterwards force an install of the new rpm you made following crash's how-to.
Haven't tested it with an active domain yet, but I can restart httpd without any errors...
...or maybe not. After I did the ownership/permission changes described in my previous post, the FP Webadmin started asking me for username/password which I though meant that it was working. But when sypplying the u/p I get a new error:
File does not exist: /var/www/vhosts/fehr.no/httpdocs/_vti_bin/_vti_adm/fpadmcgi.exe
