Resolved i have a plesk interface problem
Doruk Ozcoban
when i login plesk
can't load css or html as if the design is corrupted
Screenshot
how can i reinstall plesk interface files or how can i solve this problem?
this problem happened after the obsidian update
when i login plesk
Screenshot
Have you tried to check this behaviour with different browsers?
I had same problem. I just reran then install via console and all went well. as the plesk base files failed. when reran all went well
I am also facing a similar issue after update :/ Looking for some useful solutions. I have tried everything till now :(
I tried all repair action, but it is not fixed. Open your browser and press F12 click on console tab (or press ESC, console opening bottom), you will see Failed to load resource .
This is plesk's new upgrade problem, because browser not download all resources correctly. My login page not showing any text or images, that is very bad. I'am not configuring any domain or setting.
I said problem, but i havent got a solution. Who can fix it? i think, plesk team must be fix this bug.
#SOLVED
Connect server with RDP. Click start menu find "Plesk Reconfigurator" (If you dont find it look this location C:\Program Files (x86)\Plesk\admin\bin). Chose "Repair Plesk installation", than select all checkbox on opened window and clicked check button. That's all.
I asked my question on plesk_comminity discord channel , a good person answer my problem. That is too easy but if you dont remember, all ways is nothing :)
