I have a problem with the contab and Plesk 11.09
YannickN
for several days I've tried to activate a cron job, but nothing happened. I use the Plesk version 11.09 on openSuse 12.1 64 bit. What can I do? Bevor I have used Plesk 11.09 I have used Plesk 9.5 with no problems. I ´ve tried a lot of different things, but I have still problems. Is there anybody who can help me? Thanks a lot.....
Greetings,
Yannick
I had the same problem when try to activate cronjobs for subscriptions.
To solve the problem had to do the following:
1) Go to desired subscription
2) Go to "Web Hosting Access"
3) "Access to the server over SSH" set to "/bin/sh"
After that Cronjobs works without problems
Thanks for your help, but I have allways the same problem, after I set the full "SSH" option.
If I log in over Putty / SSH and type crontab -l I can´t find the entry from the user cron. Only the root entries are listed.
If I execute the cron via Webmin with wget path/to/my/phpfile.php I get an error message, that supposedly the file is not writable.
