I have problem with login on plesk 12.5
amir
HI
after restarted our server, we could not login to server witk http://ip:8440 or http://ip:8880
every service and website work fine and the only things we can not login to plesk, the windows just loading and we dont have any error.
I find this error on
cat /var/log/sw-cp-server/error_log
2016/03/21 11:10:41 [error] 3401#0: *496 recv() failed (104: Connection reset by peer) while reading response header from upstream, client: our ip , server: , request: "GET /login.php3?success_r
edirect_url=http%3A%2F%2F45.35.68.42%3A8880%2F HTTP/1.1", upstream: "fastcgi://unix:/var/run/sw-engine.sock:", host: "server ip:8880", referrer: "http://serverip:8880/"
I say again all the webiste and server working fine
the problem is that when I want to logn on plesk with :8443 or :8880 there I see blank page
all ther service is runing
Plesk uses its own server based on Nginx (Ports 8443 and 8880)...
/etc/sw-cp-server/
and the FPM...
/etc/sw-engine/
Websites are served via the OS packages (Ports 80 and 443)...
/etc/apache2/
and
/etc/nginx/
So you can have a situation where all the websites are running, but Plesk has problems.
Now I refer you back to my first post, please check these services are both running and check the KB.
I hope that helps
Regards
Lloyd
Can you access the 'Web Server's Default Page' via IP?
I had the similar issue. Problem was bad routing on Server IP
