Installing bandwidth limiter, multiple errors: component __asp_unix not installed
Knarf
Basic Pleskian
Parallels Plesk Panel v10.1.1, OS: Ubuntu 10.04 x86_64, 41 clients, 58 domains
During an install of the bandwidth limiter package, in the pp10.10.1-bootstrapper log multiple errors where generated like the following one, one error for each domain:
2011-02-07T22:34:19+01:00 ERR (3): Unable to apply plan changes to domain <**domain**>.nl. Error: The plan was not applied: Het component __asp_unix_support is niet geïnstalleerd, Het component __php_support is niet geïnstalleerd, phosting__php_handler_type_not_supported, Het component __perl_unix_support is niet geïnstalleerd, Het component __python_unix_support is niet geïnstalleerd, Het component fastcgi is niet geïnstalleerd, Het component __miva_unix_support is niet geïnstalleerd
The bandwidth limiter and connection checkboxes are available though.
Are these errors something to worry about?
Is it possible that some packages in my Ubuntu 10.04 are missing, such as ASP support?
In the error log, it is reported that these components are not installed: asp_unix_support, php_support, php_handler_type, perl_unix_support, python_unix_support, fastcgi, miva_unix_support.
How do I know which packages exactly are needed, and what is the best way to fix this?
