Resolved Installing Composer dependencies Problems
Killug
Debian 12
18.0.73
Problems with Laravel installation
Hello,
My name is Michel and I have been a Plesk user for many years.
Unfortunately, I had to reinstall my server. I installed Debian 12 and then apt-get update && upgrade.
I can log in to Plesk without any problems and create mail accounts, databases, and websites—everything works fine.
Now I would like to install the Laravel extension. When I install the extension from the store, it works, but when I try to create the application on my website, I get the following message:
Installing dependencies from lock file
Verifying lock file contents can be installed on current platform.
Package operations: 0 installs, 0 updates, 35 removals
> Illuminate\Foundation\ComposerScripts::prePackageUninstall
PHP Fatal error: Illuminate\Console\Command::isHidden() has #[\Override] attribute, but no matching parent method exists in /var/www/vhosts/ggstatus.cloud/httpdocs/vendor/laravel/framework/src/Illuminate/Console/Command.php on line 289
PHP Fatal error: Declaration of Monolog\Logger::emergency(Stringable|string $message, array $context = []): void must be compatible with Psr\Log\LoggerInterface::emergency($message, array $context = []) in /var/www/vhosts/ggstatus.cloud/httpdocs/vendor/monolog/monolog/src/Monolog/Logger.php on line 683
I have already tried the help I found here in the forum, but unfortunately without success. All applications are up to date.
I hope you can help me.
I look forward to your reply.
Michel
Hello,
I'll try to describe my problem again. Unfortunately, my first post was deleted for no apparent reason.
I'm trying to install Laravel on a domain in Plesk. Unfortunately, the installation isn't working and I'm getting the following error message:
Package operations: 0 installs, 1 update, 35 removals
- Downloading psr/log (3.0.2)
Both PHP and Composer are up to date.
Hello, @Killug . We have a registered bug with ID EXTPLESK-9687 and our devs are currently investigating the issue. At this point, we cannot propose any workaround. I will follow-up with more details as soon as possible. Thank you in advance for your patience in the meantime.
@Killug , thank you for your patience. Our team determined the root cause of the issue and the same was fixed in the latest release of PHP Composer extension 1.3.4. In the new extension version Composer was updated to version 2.8.12. You can update the extension following the instructions from this guide.
