Issue Problems with fresh install Plesk and Laravel
Killug
Ubuntu 24.04
18.0.74.3
Hello,
I am having an issue with a fresh installation of Plesk and Laravel. When I attempt to install Laravel, I receive the following error message:
I then logged in via SSH and entered the following:
The task "ext-laravel-task\laraveldeployskeletontask" has failed.
Installing dependencies from lock file
Verifying lock file contents can be installed on current platform.
Package operations: 0 installs, 0 updates, 35 removals
> Illuminate\Foundation\ComposerScripts::prePackageUninstall
- Removing theseer/tokenizer (1.3.1)
plesk bin extension --upgrade composer & plesk bin extension --upgrade laravel
Both times I received a message saying that the extension had been successfully installed. When I try to install Laravel, I still get the same message as described above. Unfortunately, I don't know what to do next and hope you can help me.
Hello, @Killug . Could you please confirm the version of the Composer extension? If it is below 1.3.4, please try updating it to the latest version.
Hi, thank you very much for your message. I know I've had this problem before and I found my older post. Unfortunately, I wasn't able to reproduce and fix it. I've sent a screenshot. The version is 2.8.12, a fresh new installation of Plesk.
I wish you and the team a Merry Christmas.
Thank you for the confirmation. I was able to replicate the behavior and forwarded the report to our team for further review. I will follow-up with more details as soon as possible.
Merry Christmas!
Hello, @Killug. The issue should be sorted in Laravel extension version 1.5.5-6301. Please update the extension and make sure that the data of the failed installation is removed from the document root of the domain name. Let us know if you face any further issues.
