Antrax1,
I am having the same issue and setup Amazon Route 53 per your link, thanks for that.
I purchased: "Plesk for VPS Web Host Edition"
Still am having an issues though.
Did you use your "static IP" setup in lightsail as the "value" for your record sets? I am asking because PLESK shows a different IP address for me under "Tools&Settings" Ip Addresses.
Did you disable the DNS records under the domain in PLESK or make them "Slave"
After creating the record sets in the public dns zone in Route53, I took the NS values and put them into my domain registrar. I think that's behaving, but when it goes to my static IP nothing is pointing it at my domain.
Don't seem to be having any luck.
I like Lightsail and Plesk, good easy combo for setting up and editing websites. and my first 3 worked great when I was using the DNS zones under Lightsail. Then I bought plesk and upgraded my instance went to add another DNS zone and realized the max 3 limitation.
-update 1/27
I just added my Route53 info to the plesk route53 plugin and did a mass sync. Now my domain is going to the "Web Server's Default Page" so I believe it's going to my static IP from lightsail. How do I configure plesk to have that go to my website?
Thanks for any info,
