Resolved Mailman's management links do not work
Tchiboun
Mailman is running and I've created several mailing list on a domain (for the first time I'm using mailing list).
So I receiv some mails from mailman to manage lists like to approbate a sending, but all the links are broken like :
http://lists.xxx.com/cgi-bin/mailman/admindb/test for the list called 'test' I've got a 404 not found.
I've added an SOA record : lists.xxx.xom CNAME xxx.com
I've receiv several mail but all the links to http://lists.... are not found.
Can someone help me ?
Bye.
On the documentRoot path, there is no lists directory or cgi-bin directory.
Is it a track ?
When mailing list are activated, what files do I need to have on the domain files directory ?
How can I follow the error log of mailman ?
try to check conf
run:
Code:
httpd -S | grep lists
or
Code:
apachectl -S | grep lists
command should return the output like:
Code:
# httpd -S | grep lists
port 7080 namevhost lists (/etc/httpd/conf/plesk.conf.d/server.conf:324)
wild alias lists.*
port 7081 namevhost lists (/etc/httpd/conf/plesk.conf.d/server.conf:347)
wild alias lists.*
if not, try to run rebuild configs:
Code:
plesk repair web
Hello Aleksandr,
Thanks for your reply.
This is the result :
port 7080 namevhost lists (/etc/apache2/plesk.conf.d/server.conf:151)
port 7081 namevhost lists (/etc/apache2/plesk.conf.d/server.conf:177)
Do you think I need to rebuild configs ?
Hello Aleksandr,
It looks incorrect.
Sure, try to rebuild configs.
Anyway if you not sure, so you can make backup before.
Tks,
The links is still broken.
I've run the command "plesk repair web"
and then do a test with the extension "Webserver configurations troubleshooter" with no error
would you have any other advice ?
I don't think that I've restrict cgi. How can I check it please ?
Should I reinstall mailman ?
Tkx for your help !!!
Hello, @Tchiboun
Let's start from beginning. Can you please execute
Code:
plesk version
in CLI and copy-paste result as is.
Please, also provide info about your server OS name and OS version. Then we can continue investigation.
Hello,
Tks for your help.
(In fact, the lists had never been functionnal, It's the first time my customer ask me to use it.)
Product version: Plesk Onyx 17.0.17 Update #63
Update date: 2019/08/09 06:27
Build date: 2018/12/18 11:00
OS version: Ubuntu 12.04
Revision: ab6766191d3ba26e7b21255ab007fc7fc56d84c6
Architecture: 64-bit
Wrapper version: 1.2
Thanks for reply, @Tchiboun
Because plesk 17.0 is really outdated today i can propose two solutions to achieve quick result:
- Update to latest stable 17.8 version and get all updates and bug fixes
OR
- Contact plesk support directly. I suppose this problem can be mitigated effectively only with access to a server
Thanks !
Juste a question : how force an update to 17.8 when I used to use the web interface to make update and of course the interface doesn't propose to me to update to 17.8 ?
