MAPS problem
B
baravalle
Hi everyone,
I'm, tring to setup up MAPS - not for the first time.
Every time I set up MAPs my spam decreases tenfold, which is great. At the same time, lots of mail are not delivered at all.
I don't think that they are discarded. I'm not sure actually of what happens to them - seems like they are hold in some kind of purgatory for hours.
As soon as I disable MAPs, those mails arrive.
I'm using the default MAPS server, relays.ordb.org
Any suggestions?
Andres
MAPS list
I have the following MAPS configured which works fine...
bl.spamcop.net;blackholes.mail-abuse.org;list.dsbl.org;cbl.abuseat.org;dnsbl.ahbl.org;rhsbl.ahbl.org;ircbl.ahbl.org;t1.dnsbl.net.au;combined.njabl.org;bhnc.njabl.org;dnsbl.sorbs.net;sbl-xbl.spamhaus.org
Do not use: relays.ordb.org
