    CentOS2Alma discussion
migration to 11.5 fails, nginx/ssl certificate problem
perler2
Basic Pleskian
hi,
I tried to migrate a domain from plesk 10.0.1 on ubuntu 10.04 to 11.5 on ubuntu 12.04.
the transfer fails with:
New configuration files for the Apache web server were not created due to the errors in configuration templates: nginx: [emerg] BIO_new_file("/opt/psa/var/certificates/cert3uYhKfZ") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/opt/psa/var/certificates/cert3uYhKfZ','r') error:2006D080:BIO routines:BIO_new_file:no such file) nginx: configuration file /etc/nginx/nginx.conf test failed . The error message containing the detailed error descriptions was sent to you by e-mail. Please resolve the issues and click here to generate broken configuration files once again or here to generate all configuration files.
I removed the default certificate and replaced it with our own, so this could be the problem? this is the certificate directory just after the attempted transfer:
Code:
root@host:/opt/psa/var/certificates# ls -lisa
total 32
33423449 4 drwxr-xr-x  2 root   root   4096 Aug 28 19:21 .
33423446 4 drwxr-xr-x 11 psaadm psaadm 4096 Aug 23 12:55 ..
33427903 8 -r--------  1 psaadm psaadm 4352 Aug 23 13:01 cert-831MIf
33428023 4 -r--------  1 root   root   2212 Aug 28 19:21 cert-m1BXOq
33427904 4 -r--------  1 psaadm psaadm 2212 Aug 23 13:01 cert-rhFwIi
33428022 8 -r--------  1 root   root   4352 Aug 28 19:21 cert-Z7k16k
the installation is virgin, any idea what's wrong here?
Try to troubleshoot it more deeply with help of this tool - http://kb.parallels.com/115587
thanks, I did this, but don't see much that would help me:
that's what happens, when I click "nginxDomainVhost":
Error: Can not obtain file information: Unable to execute filemng: filemng: stat failed: No such file or directory System error 2: No such file or directory
Error: Can not obtain file information: Unable to execute filemng: filemng: Error occurred during /bin/cat command.
ConfigurationsBootstrapsLogs Search...Checker
/opt/psa/admin/conf/nginx_vhosts_bootstrap.conf
File Information
File Contents ( plain | colored | raw )
What sort of output of following command:
# plesk bin repair --update-vhosts-structure
The structure of the home directory was successfully updated on virtual hosts.
oh, and the error is gone. is there a way to prevent the error when transferring, as we plan to move quite lot domains at once?
