MSSQL Problem
CahitE
Basic Pleskian
I have some domains which use mssql yesterday suddenly my mssql server has stopped.
and then i tryed to restart it but nothing worked . When i remove temp dbs from the data directory my mssql start to working but this time i got this error when i want to remove or modify old dbs
on the plesk panel :
When i want to create a new subscription on my plesk admin panel it returns me an error as this :
Delete database user failed: Database 'roportaj' cannot be opened due to inaccessible files or insufficient memory or disk space. See the SQL Server errorlog for details.
---------------------- Debug Info -------------------------------
0: DatabaseManagerMSSQL.php:52
DatabaseManagerMSSQL->dropUserImpl(string 'erm123', string 'roportaj')
1: DatabaseManager.php:106
DatabaseManager->deleteDatabase(object of type Database)
2: class.DataBasesList.php:239
DataBasesList->remove(array)
3: removeDataBases.php3:41
And on the my little admin :
Error -2147467259
Cannot open user default database. Login failed.
Provider=sqloledb;Data Source=localhost;User Id=xxxx;Password=xxxxxx;
One more note i tryed webservmngr for to reconfigure the hosts which has mssql db and checked folder and file permissions for network services
