• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
MyODBC driver problem
jovana
Okay, I had a problem with MySQL 5 query's in combination using Plesk 8.1 and MySQL 5. I want to share the solution with you, and maby SWsoft can als fix this problem in the next release.
The Problem:
A normal simple query like:
select * from table; does not work.
The workaround:
Modify your query to:
select id, name, date from table; does work well.
The solution:
After a search on the mysql bug report site, I found this is a known problem.
In the Plesk 8.1 installation package there is the MySQL 3.51.11 driver shipped. This is a wrong driver in combination of MySQL 5. To have this problem fixed download (http://dev.mysql.com/downloads/connector/odbc/3.51.html) the latest one, 3.51.12 driver. Al problem are gone.
jovana, thank you for your report. We will update MySQL ODBC in Plesk distribution in the next major version.
