Need Components Management help
A
AjayJ
I am unable to find ASP 6.0.3790.4195
anybody can help how can i enable it?
You should go to Add/Remove Programs - > Windows components -> IIS and select ASP there for installation.
I am unable to find IIS and select ASP
at Add/Remove Programs - > Windows components -> please suggest..
Look in Add/Remove Windows Components in the left pane. It is Internet Information Services (IIS), the fourth item in the list.
