Need help changing IP address
baker011
I had my plesk set up on a cloud VPS and I recently needed to upgrade it. Sadly only option was to take a snapshot and transfer that to a whole new setup. Problem with this is it brought all the original settings over, like the old servers IP address.
I have managed to update the IP address for each domain, but the host IP is still showing the old one. How can I update that?
Thanks for any help.
Hi Baker011,
You can assign you server Ip by login to Plesk->Tools&Settings->IP Addresses.
Also, You can change the ip address of the domain from Plesk->Domains->Hosting Settings.
Thank you,
