Need help, multiple installing aps in plesk
M
Muhammad SyafiqM
Hello everyone,
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Parallel Plesk 10, Linux
PROBLEM DESCRIPTION
Try to installing multiple aps which wordpress and smartermail in plesk but stuck on error "
"This directory cannot be used because it would be overlapped by another app installed at httpdocs. Such overlapping would make the app unavailable"
STEPS TO REPRODUCE
ACTUAL RESULT
EXPECTED RESULT
ANY ADDITIONAL INFORMATION
Anyone have same problem like this?
The error is caused by the fact that another application is installed into root domain's directory ("/"). One of applications conflicts with other applications installed into domain's root directory ("/").
We have already submitted request to developers regarding this behaviour. I hope it will be resolved soon.
Hi IgorG, thanks your fast response.
Anyway, how if the scenario - 1. wordpress installed in /wordpress and 2. xandmail installed in /xandmail? Is any possible to run both application? Or 1 click install for single application can install in parallel plesk?
Thanks,
I think that this scenario should work. You can try at least.
