    CentOS2Alma discussion
  • Please beaware of a breaking change in the REST API on the next Plesk release (18.0.62).
    Starting from Plesk Obsidian 18.0.62, requests to REST API containing the Content-Type header with a media-type directive other than “application/json” will result in the HTTP “415 Unsupported Media Type” client error response code. Read more here
need help
cyanda
Hello
My server got hacked
and all the index.php en index.html are changed
so the panel dont work anymore
can do just a reinstall on a working server so i dont lose the data
any sugestions ?
Hello,
Your server is hacked so I will suggest you please setup new server and install server security packages and then mitigate your all sites to new server, Because hacker has found the backdoor on your server OS and due to that you will have to reinstall your server OS
