Need help!
D
deadbyte
I'm upgrading from 6.0 to 7.5
Everything goes ok with installation until I get this message:
Installing packages
Installing php-pgsql-4.3.2-psa.rh9.1.i386.rpm
error: Failed dependencies:
php = 4.3.2-psa.rh9.1 is needed by php-pgsql-4.3.2-psa.rh9.1
Not all required packages were installed.
Press <ENTER> to continue...
what should I do to proceed?
ok I figure this out, but when I try to restart plesk..
# service psa restart
===> Reading /etc/psa/psa.conf ...
PSA is down, perfoming full restart.
Starting MySQL: [ OK ]
Starting spamd: [ OK ]
Starting psa-spamassassin service: [ OK ]
Key read failed
Key read failed
Bad key: ui
Bad key: read init
Bad key: read init
/usr/local/psa/admin/bin/httpsdctl start: httpd could not be started
Starting Plesk: [FAILED]
I tried forcing installation:
rpm -Uvh --force psa-7.5.1-rh9.build75041216.14.i586.rpm
Here's what I get:
VERSION MISMATCH:
PLESK DATABASE VERSION: 070
PLESK INSTALLATION VERSION: 075
ERROR while trying to check version match
Check the error reason(see log file: /tmp/psa_7.5.1_RedHat_9_build75041216.14_upgrade.log), fix and try again
anyone know what should I do?
Can anyone from Plesk please help me? I've tried contacting ev1servers.net but they seem not to be able to fix my problem.
I also tried filling a support form in sw-soft site, but since my plesk is down I can't find my 6.0 license number to fill the form.
Please help me!
never mind this, after a big time of frustration I had a system restore with new versio of plesk. :rolleyes:
