NGINX problem.
Centralweb
Hi.
We installed Plesk 11.0.5 on a CentOS 6.4 X64, When we login to the admin area, this warning shown:
New files of configuration for Apache web server were not built due to errors in configuration templates: nginx: [emerg] bind() to [2a01:4f8:162:4242::2]:80 failed (99: Cannot assign requested address) nginx: configuration file /etc/nginx/nginx.conf test failed . The detailed error message was e-mailed to you, so please check the e-mail, fix the errors, and click here to retry generating broken configuration or click here to retry generating of all configurations.
We don't want to use nginx and we disable it also, but this issue did not solved yet. What we should do?
Best regards
Have you tried rebuilding all the vhosts with:
Code:
 /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
Fastest as you investigate is to edit /etc/nginx/nginx.conf and change the default listen port to something else other than default 80.
