P_heck
Basic Pleskian
Hello,
OS Debian 7.8
Plesk version 12.0.18 Update #62
Changed from Apache to NGINX and everything works fine - only problem I have is with the monitoring with OMD/check_mk using the nginx_status plugin:
The plugin states a "netstat -tlnp" (line 35) and then looks for a process called "nginx" (definition in line 45).
After I have changed nginx related entries in the Plesk panel, nginx will be automatically restarted by Plesk and the output from netstat now shows:
"1511/nginx: worker"
So the plugin returns an empty value (as it expects nginx without the colon) causing a warning in the OMD console.
After restarting NGINX on the commandline (service nginx restart), the netstat output now reads:
"5368/nginx"
which is then ok for the monitoring!
Looks for me, that the restart initiated by the panel is causing this different behavior.
Anyone any idea how to avoid nginx starting with the ":_ worker" parameter?
Ciao Peter
OS Debian 7.8
"5368/nginx"
Ciao Peter
