Forwarded to devs [PES extension] Clam still active and running after disabling and removing PES
Kaspar
API expert
Plesk Guru
User name: Rasp
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
CentOS 7.8.2003 (Core), Plesk 18.0.27 Update #1, PES 1.0.5-184
PROBLEM DESCRIPTION
ClamAV gets installed with the PES extension (which IMHO is a great feature). However when disabling and removing the PES extension (using the Plesk UI) ClamAV remains running as a process and is not removed. Which is unfortunate as ClamAV hogs up quite some resources.
STEPS TO REPRODUCE
Simply Install the PES extension and remove it after installations trough the Plesk GUI.
ACTUAL RESULT
After installation ClamAV is still running on the system.
EXPECTED RESULT
ClamAV should be removed as well (oir perhaps at least have an option to remove clamAV when removing the PES extension ).
ANY ADDITIONAL INFORMATION
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
Thank you for the report.
According to developers, this was already resolved in the current development version 1.1.0. The release is planned by the end of this month.
