please speed up backup and restore system
Jens Johansson
Basic Pleskian
Hi there,
in Plesk 12.0.18, you can only backup everything below a subscription. For very many files the process takes more than 1 hour:
/var/www/vhosts/
folder1: 114034
folder2: 123030
folder3: 206226
Unfortunately you can only restore everything. The restoration lasted 3 hours! In Confixx it takes only 30 minutes. The process in Confixx was different. All was packed in zip and moved to /backup. This method feels up to 10000% faster.
Here a workaround: copying the necessary folders manually in Plesk -> Files -> Copy.
This procedure is with many files 10000% faster.
Odin-Support:
1) please speed up the backup and restore system
2) please add: backup individual files
3) Possibly better method as in Confixx: zipping and move ?
Have you read about backup/restore system improvements in upcoming Plesk 12.5?
Hi Igor,
unfortunately not help informations under: http://download1.parallels.com/Ples...inistrator-guide/index.htm?fileName=59263.htm
An incremental Backups is faster, but the main problem remains. Has a folder a lot of files, takes the recovery very long. A shop software is usually (including pictures) of about 50,000 files, with cache roundabout 70,000 to 100,000 files. A recovery takes then about 2-3 hours.
If the process is changed in Plesk 12.5? If it speeds up?
