plesk 10.3 HTTPS problem
X
xzodwild
hi
i have plesk 10.3 on ubuntu server 10.04LTS 64bits
i setup a dmain, lets say www.mydom.com
i installed a CMS in subdomain => subdom.mydom.com
to access administration of this CMS i go to http://subdom.mydom.com/adminxxx that works very well
the problem is when i try to access in HTTPS => HTTPS://subdom.mydom.com/adminxxx
it goes to the main page https://www.mydom.com !
in facts, whatever subdomain i try to access in https go to main https://www.mydom.com
there is no ssl certificate installed, no https, ssl parameters setup
how can i fix that ?
Check your SSL settings
Do you have enabled the SSL settings at your hosting plans?
Have you installed a exclusive IP on that domain?
Make a good installation of your SSL certificate at the domain!
i'm not sure where can i find all that ?
i do not have ssl certificate and i do not want one. its for private use.
i used to use a classic commercial hosting and that was working well.
i guess there is something to do in config files but i don't know what and where
