Plesk 12.5 | MySQL 5.6 | Cent OS 6.5 | Plesk Panel 'Application Vault' Issue
PriyanA
Regular Pleskian
I have upgraded MySQL 5.1 to 5.6 successfully.
Everything works fine. Except for Plesk Panel > Tools & Setting > 'Application Vault'
Error Message,
Internal error: ODBC error #01000: [unixODBC][Driver Manager]Can't open lib '/usr/lib64/libmyodbc5.so' : file not found
Message ODBC error #01000: [unixODBC][Driver Manager]Can't open lib '/usr/lib64/libmyodbc5.so' : file not found
File aps_php.php
Line 11933
Type Exception
I understand /usr/lib64/libmyodbc5.so no longer there.
I can downgrade to mysql-connector-odbc-5.1.5r1144-7.el6
then I get this Error message by accessing 'Application Vault'
502 Bad Gateway
nginx
How can I resolve this issue?
Thank You!
Current connector version installed by upgrading to MySQL 5.6 using YUM is,
mysql-connector-odbc.x86_64 5.3.4-1.el6
I receive this error message by accessing 'Application Vault'
Error Message,
File aps_php.php
Line 11933
Type Exception
-rwxr-xr-x 1 root root 4300760 Jun 19 2014 /usr/lib64/libmyodbc5a.so
-rwxr-xr-x 1 root root 4299448 Jun 19 2014 /usr/lib64/libmyodbc5w.so
Thank you IgorG
Try to create symlink /usr/lib64/libmyodbc5.so to one of these files and check results.
Thank you!!! It worked!
#cd /usr/lib64/
#ln -s libmyodbc5w.so libmyodbc5.so
Then,
#ln -s /var/lib/mysql/mysql.sock /tmp/mysql.sock
Thank you IgorG
