L
linuxcrazy
I upgraded my CentOS 4 using "yum upgrade" and everything went fine. With other updates Mysql version was upgraded to 5.0.51 as shown by execution of command
rpm -qa mysql
mysql-5.0.51-1.el4.art
logon to mysql database server via command prompt works fine but logging on to Plesk admin panel is yielding the following error:
ERROR: PleskFatalException
bad column in table: `Column_priv` set('Select','Insert','Update','References') character set utf8 NOT NULL default '',
0: /usr/local/psa/admin/plib/common_func.php3:153
psaerror(string 'bad column in table: `Column_priv` set('Select','Insert','Update','References') character set utf8 NOT NULL default '',')
1: /usr/local/psa/admin/plib/SQLParser.php:119
SQLParser->parseError(string ' `Column_priv` set('Select','Insert','Update','References') character set utf8 NOT NULL default '',')
2: /usr/local/psa/admin/plib/SQLParser.php:105
SQLParser->_parseLineInTable(string ' `Column_priv` set('Select','Insert','Update','References') character set utf8 NOT NULL default '',')
3: /usr/local/psa/admin/plib/SQLParser.php:52
SQLParser:
arseLine(string ' `Column_priv` set('Select','Insert','Update','References') character set utf8 NOT NULL default '',', integer '7')
4: :
array_walk(array, array)
5: /usr/local/psa/admin/plib/SQLParser.php:23
SQLParser->getArray(array)
6: /usr/local/psa/admin/plib/SQLParser.php:30
SQLParser->handleDatabase()
7: /usr/local/psa/admin/plib/MySQL5FixBinaryColumns.php:36
MySQL5FixBinaryColumns::run()
8: /usr/local/psa/admin/auto_prepend/auth.php3:93
I tried to google for similar error and solution but no luck.
Can anybody suggests the reason and possible solution to this problem? Your help is highly appreciated.
Thanks
rpm -qa mysql
SQLParser:
4: :
Thanks
