Plesk Gameserver-Modul Problem
xxxxxxx
OS: Debian 6.0.6 (32-bit)
Plesk Panel-Version: 11.0.9 Update #32
Gameserver_Modul-Licence: Yes
Hello,
I installed Plesk Game Server Module and discovered that the Counter-Strike:Source Server can not install.
Since Valve has changed the folder structure of the installation appears to no longer work.
I do need an Update or a Fix for the Gameserver-Modul
Thx for your help
Parallels.com apparently has no interest in that problems are eliminated.
The main thing parallels.com can collect license fees.
My statement ziehlt out that only by parallels.com problem to be solved is simply ignored.
