Plesk problem after FreeBSD upgraded!!
T
ttk_2k
Hi, I'm very new to Plesk.
I've just got a problem with Plesk after I use CVSup renewed my FreeBSD.
I was having FreeBSD 5.3 before I run CVSup, however after running that it upgraded my FreeBSD to 5.4.. I didn't know it would upgrade my FreeBSD to 5.4.
Now I can't use Updater in Plesk Admin panel, it shows the error:
Error: You are using FreeBSD 5.4, but autoinstaller was compiled for FreeBSD 5.3. Exiting autoinstaller.
I'm afraid if there are any other issues if I didn't upgrade my system via Plesk.
Please help me.. thanks.
PS: is that wrong to use CVSup for renewing our FreeBSD when we have Plesk installed??
