Plesk Problem, need help please
christiano1203
Basic Pleskian
Hello,
today i received this Error Message when i try to change php value for a Domain. Can somebody help me to fix it?
Error: ProtDirUser_IIS::update() failed: Update Protected Directory #427 user failed: no such table: ProtectedUrls (Error code 1)
Thanks for helping...
Try to run
C:\Program Files (x86)\Parallels\Plesk\bin>repair.exe --synchronize-protected-directories-storage
Hello Igor,
thanks for your helping, but know, yet my password protetecd directories dont work anymore :(
A protect folder dont ask user and password more....can you help to fix this problem?
Thank you..
hello
after update to 11.5.30 have error
on use this :
get this:
no such table: ProtectedUrlUsers
(Error code 1)
hello
on use this :
get this:
(Error code 1)
Looks like that database C:\Program Files (x86)\Parallels\Plesk\admin\db\UrlProtection.db is corrupted. I suggest you contact Support Team for fixing it directly on your server.
I copy UrlProtection.db file from other server to that and fix.
but now get this error.
on make new email get this error:
Error: Source: Microsoft OLE DB Provider for SQL Server
Description: 'encrypt' is not a recognized built-in function name.
pleas help me.
I suppose that your Plesk was not correctly upgraded. I suggest you contact Support Team for fixing all post-upgrade issues directly on your server. There is KB article with similar issue - http://kb.parallels.com/116131 You can try to switch database engine at least.
