plz i need urgent help (i lost plesk 10)
A
AyazA
Hello
i was trying to remove some modules but that time unfortunately i lost Plesk Panel 10.1.1 package files but all my websites data and databases are present then after that i try to repair my plesk panel through below command:
# /usr/local/psa/admin/sbin/autoinstaller --select-release-id PLESK_10_1_1 --upgrade-installed-components
but it giving error me:
[root@NSW ~]# /usr/local/psa/admin/sbin/autoinstaller --select-release-id PLESK_10_1_1 --upgrade-installed
File downloading products.inf3: 100% was finished.
File downloading plesk.inf3: 11%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading ppsmbe.inf3: 10%..31%..51%..62%..72%..93%..100% was finished.
File downloading sitebuilder.inf3: 10%..22%..35%..48%..61%..74%..87%..100% was finished.
File downloading sso.inf3: 13%..27%..54%..67%..81%..94%..100% was finished.
File downloading setemplates.inf3: 44%..69%..94%..100% was finished.
File downloading pp-sitebuilder.inf3: 30%..65%..82%..99%..100% was finished.
File downloading billing.inf3: 21%..34%..46%..58%..71%..83%..95%..100% was finished.
File downloading mysql.inf3: 100% was finished.
Checking for installed packages...
File downloading PSA_10.1.1/plesk-10.1.1-cos5-i386.inf3: 10%..21%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_10.1.1/plesk-patches-10.1.1-cos5-i386.inf3: 10%..20%..34%..40%..50%..62%..70%..80%..90%..100% was finished.
File downloading SITEBUILDER_5.1.0/sitebuilder-5.1.0-rhall-all.inf3: 100% was finished.
File downloading BILLING_10.1.0/billing-10.1.0-rhall-all.inf3: 100% was finished.
File downloading MYSQL_5.1/mysql-5.1-rhel5-i386.inf3: 35%..81%..100% was finished.
Parallels Containers were detected. Trying to connect to VZAgent...Warning! Failed to connect to VZAgent: ioctl: Transport endpoint is not connected
Detecting installed product components.
Gathering information about installed license key...
Retrieving information about the installed packages...
File downloading SITEBUILDER_5.1.0/dist-rpm-RedHat-all-all/build-5.1.0-rhall-all.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading SITEBUILDER_5.1.0/thirdparty-rpm-RedHat-all-all/thirdparty-5.1.0-rhall-all.hdr.gz: 100% was finished.
File downloading PSA_10.1.1/dist-rpm-CentOS-5-i386/build-10.1.1-cos5-i386.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_10.1.1/update-rpm-CentOS-5-i386/update-10.1.1-cos5-i386.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_10.1.1/thirdparty-rpm-CentOS-5-i386/thirdparty-10.1.1-cos5-i386.hdr.gz: 12%..38%..45%..51%..61%..71%..81%..91%..100% was finished.
File downloading SITEBUILDER_5.1.0/update-rpm-RedHat-all-all/update-5.1.0-rhall-all.hdr.gz: 100% was finished.
File downloading BILLING_10.1.0/thirdparty-rpm-RedHat-all-all/thirdparty-10.1.0-rhall-all.hdr.gz: 100% was finished.
File downloading BILLING_10.1.0/dist-rpm-RedHat-all-all/build-10.1.0-rhall-all.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading BILLING_10.1.0/update-rpm-RedHat-all-all/update-10.1.0-rhall-all.hdr.gz: 100% was finished.
Determining the packages that need to be installed.
ERROR: Unable to install the "pp-sitebuilder-5.1.0-34158.10122501.noarch" package.
The following could cause the installation failure:
1) pp-sitebuilder-5.1.0-34158.10122501.noarch: No suitable solutions were found
for the "plesk-core >= 10.1.0" dependency.
2) plesk-core-10.10.1-cos5.build1010110120.18.i386: No suitable solutions were found
for the "psa-php-configurator >= 1.6.1" dependency.
3) psa-php5-configurator-1.6.1-cos5.build1010110207.15.noarch: No suitable solutions were found
for the "php" dependency.
There were also other problems encountered. For details,
refer to the log file: /tmp/autoinstaller3.log.
Not all packages were installed.
Please, contact product technical support.
plz need urgent help coz my all websites are down from last 6 hours
thanks
ayaz ali
in SSH run this
export PLESK_QUOTACHECK_OFF=1
/usr/local/psa/bootstrapper/pp10.10.1-bootstrapper/bootstrapper.sh repair
That should fix it and bring everything online when done.
IN SSH did you try
service httpd restart
in SSH run this
IN SSH did you try
i try it by SSH but not working with me
SSH command logos:
[root@NSW ~]# export PLESK_QUOTACHECK_OFF=1
[root@NSW ~]# /usr/local/psa/bootstrapper/pp10.10.1-bootstrapper/bootstrapper.sh repair
-bash: /usr/local/psa/bootstrapper/pp10.10.1-bootstrapper/bootstrapper.sh: No such file or directory
[root@NSW ~]#
thanks
ayaz ali
Log into parallels and download the auto installer
Auto install through SSH
This will repair installation then. Something happened to the install.
If you are using CentOS 5 / Redhat ES 5 32 bit
wget http://download1.parallels.com/Ples...taller_v3.7.1_build101103.18_os_CentOS_5_i386
chmod 0777 parallels_installer_v3.7.1_build101103.18_os_CentOS_5_i386
./parallels_installer_v3.7.1_build101103.18_os_CentOS_5_i386
If you are using CentOS 5 / RedHat ES 5 64 bit
wget http://download1.parallels.com/Ples...ller_v3.7.1_build101103.18_os_CentOS_5_x86_64
chmdo 0777 parallels_installer_v3.7.1_build101103.18_os_CentOS_5_x86_64
/parallels_installer_v3.7.1_build101103.18_os_CentOS_5_x86_64
thanks for reply.
i done all above instructions but still i geting problem
File downloading PSA_10.1.1/thirdparty-rpm-CentOS-5-i386/thirdparty-10.1.1-cos5-i386.hdr.gz: 12%..22%..32%..42%..51%..61%..71%..81%..91%..100% was finished.
ERROR: Unable to install the "psa-php5-configurator-1.6.1-cos5.build1010110207.15.noarch" package.
1) psa-php5-configurator-1.6.1-cos5.build1010110207.15.noarch: No suitable solutions were found
2) php-5.1.6-27.el5_5.3.i386: No suitable solutions were found
for the "php-cli = 5.1.6-27.el5_5.3" dependency.
3) Unable to downgrade 'php-cli' package to version 5.1.6-27.el5_5.3:
version 5.2.14-2.el5.art is currently installed.
and when i try to service httpd restart it also give me error:
[root@NSW ~]# service httpd restart
Stopping httpd: [FAILED]
Starting httpd: Syntax error on line 3 of /var/www/vhosts/newsoftworld.com/conf/vhost.conf:
Invalid command 'php_admin_value', perhaps misspelled or defined by a module not included in the server configuration
[FAILED]
how i can fix it
thanks for reply.
[root@NSW ~]# php -v
PHP 5.2.14 (cli) (built: Aug 12 2010 15:37:18)
Copyright (c) 1997-2010 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies
with XCache v1.3.0, Copyright (c) 2005-2009, by mOo
you may need to
yum remove psa-php5-configurator
This will effectivly uninstall plesk at the same time as it cleans up installation of php.
and then run the auto installer again
i alreayd try the above instruction but still failed
[root@NSW ~]# yum remove psa-php5-configurator
Loaded plugins: fastestmirror
Setting up Remove Process
No Match for argument: psa-php5-configurator
Loading mirror speeds from cached hostfile
* addons: centos-distro.cavecreek.net
* atomic: www6.atomicorp.com
* base: dist1.800hosting.com
* extras: mirror.rackspace.com
* updates: mirror.umoss.org
addons | 951 B 00:00
atomic | 1.9 kB 00:00
atomic/primary_db | 485 kB 00:00
base | 2.1 kB 00:00
extras | 2.1 kB 00:00
updates | 1.9 kB 00:00
No Packages marked for removal
Installation types for the product:
1. (*) Typical
Install typically used components. Recommended for general use.
2. ( ) Full
Install all components.
3. ( ) Custom
Custom components selection. Recommended only for experienced users.
N) Continue installation with selected type; P) Go the previous page; Q) Cancel installing;
L) View or change components marked for installation;
To select an installation type or choose another product, type the respective number;
Select an action [N]: N
for the "php5-ioncube-loader >= 4.0" dependency.
2) php5-ioncube-loader-4.0.5-11020715.i386: No suitable solutions were found
for the "php < 5.4.0" dependency.
3) php-5.1.6-27.el5_5.3.i386: No suitable solutions were found
ok and i going try above instuction and is it fresh installation and what above my all data it will be lost or not coz i have no backup of my data due to plesk broken.
also plz how i can save my all data from losing
scratch all instructions except this.
You shouldn't loose any data... and when plesk reinstalls it normally reattaches to the previous install.
yesterday i uninstalled plesk and reinstalled and it worked.
As for backup i would backup the /var/www/vhosts folder (all domains content) and the mysql databases to a folder /backup or something.
Could even use rsync to copy it to the other folder.
So try this...
wget http://www.atomicorp.com/installers/atomic
chmod 0777 atomic
./atomic
wget http://www.atomicorp.com/installers/plesk
chmod 0777 plesk
./plesk
./parallels_installer_v3.7.1_build101103.18_os_CentO S_5_i386
paste results
i already done above instruction and now what i need to do more:
[root@NSW ~]# wget http://www.atomicorp.com/installers/atomic
--2011-02-22 00:49:45-- http://www.atomicorp.com/installers/atomic
Resolving www.atomicorp.com... 74.208.155.133
Connecting to www.atomicorp.com|74.208.155.133|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12076 (12K) [text/plain]
Saving to: `atomic'
100%[====================================================================================================>] 12,076 --.-K/s in 0.04s
2011-02-22 00:49:45 (276 KB/s) - `atomic' saved [12076/12076]
[root@NSW ~]# chmod 0777 atomic
[root@NSW ~]# ./atomic
Atomic Archive installer, version 1.4
BY INSTALLING THIS SOFTWARE AND BY USING ANY AND ALL SOFTWARE
PROVIDED BY ATOMICORP LIMITED YOU ACKNOWLEDGE AND AGREE:
THIS SOFTWARE AND ALL SOFTWARE PROVIDED IN THIS REPOSITORY IS
PROVIDED BY ATOMICORP LIMITED AS IS, IS UNSUPPORTED AND ANY
EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL ATOMICORP LIMITED, THE
COPYRIGHT OWNER OR ANY CONTRIBUTOR TO ANY AND ALL SOFTWARE PROVIDED
BY OR PUBLISHED IN THIS REPOSITORY BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
OF THE POSSIBILITY OF SUCH DAMAGE.
Do you agree to these terms (yes/no): yy^H
Please enter yes or no
Do you agree to these terms (yes/no): yes
Configuring the [atomic] yum archive for this system
Installing the Atomic GPG key: OK
Downloading atomic-release-1.0-13.el5.art.noarch.rpm: OK
The Atomic Rocket Turtle archive has now been installed and configured for your system
The following channels are available:
atomic - [ACTIVATED] - contains the stable tree of ART packages
atomic-testing - [DISABLED] - contains the testing tree of ART packages
atomic-bleeding - [DISABLED] - contains the development tree of ART packages
then next what i need to do....
[root@NSW ~]# wget http://www.atomicorp.com/installers/plesk
--2011-02-22 00:58:00-- http://www.atomicorp.com/installers/plesk
Length: 9924 (9.7K) [text/plain]
Saving to: `plesk'
100%[=================================>] 9,924 --.-K/s in 0.04s
2011-02-22 00:58:00 (223 KB/s) - `plesk' saved [9924/9924]
[root@NSW ~]# chmod 0777 plesk
[root@NSW ~]# ./plesk
Plesk repo installer, version 1.0
Configuring the [plesk] yum archive for this system
Would you like to add the Plesk yum repository to the system?
Enable Plesk repository? (y/n) [Default: n]: y
Use Qmail or Postfix? (qmail/postfix) [Default: postfix]: qmail
The Plesk archive has now been installed and configured for your system
plesk - [ACTIVATED] - contains the stable tree of Plesk packages
Choose Plesk admin password [Random: 27531]: 123456789
* addons: mirror.ncsa.illinois.edu
* base: mirror.unl.edu
* updates: mirror.unl.edu
base | 2.1 kB 00:00
plesk | 951 B 00:00
plesk/primary | 74 kB 00:00
plesk 191/191
Excluding Packages from Plesk Server Administrator
Finished
Setting up Install Process
Package matching psa-autoinstaller-3.6.0-100413.11.i386 already installed. Checking for update.
Resolving Dependencies
--> Running transaction check
---> Package psa.i586 0:9.5.3-cos5.build95101022.06 set to be updated
atomic/filelists_db | 684 kB 00:00
plesk/filelists | 899 kB 00:00
--> Processing Dependency: psa-locale-base = 9.5.3 for package: psa
--> Processing Dependency: psa-mail-driver >= 1.0.0 for package: psa
--> Processing Dependency: psa-php-configurator >= 1.5.3 for package: psa
--> Processing Dependency: psa-api >= 9.5.3 for package: psa
--> Processing Dependency: plesk-base >= 9.5.3 for package: psa
--> Processing Dependency: awstats for package: psa
--> Processing Dependency: /usr/local/psa/admin/htdocs/locales/default for package: psa
--> Processing Dependency: mod_perl for package: psa
--> Processing Dependency: plesk-skins-9.5.3 for package: psa
--> Processing Dependency: /usr/local/psa/bin/sw-engine-pleskrun for package: psa
--> Processing Dependency: psa-proftpd-start for package: psa
--> Processing Dependency: webalizer for package: psa
--> Processing Dependency: psa-libpam-plesk for package: psa
--> Processing Dependency: psa-logrotate for package: psa
---> Package awstats.noarch 0:6.6-1.swsoft set to be updated
---> Package mod_perl.i386 0:2.0.4-6.el5 set to be updated
---> Package plesk-base.i586 0:9.5.3-cos5.build95101022.06 set to be updated
--> Processing Dependency: sw-engine >= 2.0-5 for package: plesk-base
---> Package psa-api.noarch 0:9.5.3-cos5.build95101022.06 set to be updated
---> Package psa-libpam-plesk.i586 0:9.5.3-cos5.build95101022.06 set to be updated
--> Processing Dependency: psa-pylibplesk >= 8.0.0 for package: psa-libpam-plesk
---> Package psa-locale-base-en-US.noarch 0:9.5.3-2010071512 set to be updated
---> Package psa-logrotate.i586 0:3.7-cos5.build95101022.06 set to be updated
---> Package psa-mail-qc-driver.i586 0:1.0.0-cos5.build95101022.06 set to be updated
--> Processing Dependency: psa-qmail >= 1:1.03 for package: psa-mail-qc-driver
--> Processing Dependency: courier-imap >= 3.0.8 for package: psa-mail-qc-driver
--> Processing Dependency: psa-qmail-rblsmtpd for package: psa-mail-qc-driver
--> Processing Dependency: psa-mail-driver-common for package: psa-mail-qc-driver
---> Package psa-php5-configurator.noarch 0:1.5.3-cos5.build95101022.06 set to be updated
--> Processing Dependency: php for package: psa-php5-configurator
---> Package psa-proftpd-xinetd.i386 0:1.3.3c-3.el5.art set to be updated
--> Processing Dependency: psa-proftpd = 1.3.3c-3.el5.art for package: psa-proftpd-xinetd
---> Package webalizer.i386 0:2.01_10-30.1 set to be updated
---> Package courier-imap.i586 0:3.0.8-cos5.build95101022.06 set to be updated
---> Package php.i386 0:5.2.17-1.el5.art set to be updated
--> Processing Dependency: php-common = 5.2.17-1.el5.art for package: php
--> Processing Dependency: php-cli = 5.2.17-1.el5.art for package: php
---> Package psa-mail-driver-common.i586 0:9.5.3-cos5.build95101022.06 set to be updated
---> Package psa-proftpd.i386 0:1.3.3c-3.el5.art set to be updated
---> Package psa-pylibplesk.i586 0:9.5.3-cos5.build95101022.06 set to be updated
---> Package psa-qmail.i586 1:1.03-cos5.build95101022.06 set to be updated
---> Package psa-qmail-rblsmtpd.i586 0:0.70-cos5.build95101022.06 set to be updated
---> Package sw-engine.i386 0:2.0-5.201006091004.centos5 set to be updated
---> Package php-cli.i386 0:5.2.17-1.el5.art set to be updated
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-xml
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-mysql
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-pdo
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-mbstring
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-imap
--> Processing Dependency: php-common = 5.2.14-2.el5.art for package: php-gd
---> Package php-common.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-gd.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-imap.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-mbstring.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-mysql.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-pdo.i386 0:5.2.17-1.el5.art set to be updated
---> Package php-xml.i386 0:5.2.17-1.el5.art set to be updated
--> Finished Dependency Resolution
psa-9.5.3-cos5.build95101022.06.i586 from plesk has depsolving problems
--> Missing Dependency: plesk-skins-9.5.3 is needed by package psa-9.5.3-cos5.build95101022.06.i586 (plesk)
Error: Missing Dependency: plesk-skins-9.5.3 is needed by package psa-9.5.3-cos5.build95101022.06.i586 (plesk)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
./plesk: line 326: /usr/local/psa/bin/init_conf: No such file or directory
Plesk installation is complete. Your plesk admin credentials are:
Username: admin
Password: 123456789
./plesk: line 335: /usr/local/psa/bin/init_conf: No such file or directory
so the plesk respository attempts to install 9.5.3... well thats not good.
what about hte last one
still failed installation
1. (*) Typical
2. ( ) Full
3. ( ) Custom
Select an action [N]: N'
To select or deselect an item, type the respective number.
To perform an action, type the respective letter.
Please type a number or letter:
N
File downloading PSA_10.1.1/thirdparty-rpm-CentOS-5-i386/thirdparty-10.1.1-cos5-i386.hdr.gz: 12%..22%..32%..45%..51%..61%..71%..81%..91%..100% was finished.
File downloading BILLING_10.1.0/dist-rpm-RedHat-all-all/build-10.1.0-rhall-all.hdr.gz: 10%..20%..30%..40%..50%..60%..72%..80%..90%..100% was finished.
Run a backup...
Uninstall php
yum remove php
Then reinstall plesk with that auto responder.
You are having version problems with php 5.1.6 and 5.2.14
how i can run backup coz my plesk not working...i need database and all site data backup.
then i need to remove php.
i already made a backup of my all database and websites data by SSH in main VPS directory and os is that right.
i am still waiting for ur reply
thanks
