plz i need urgent help (i lost plesk 10)
i alreayd done the above php removing instruction and now what i need to do next
[root@NSW ~]# yum remove php
Loaded plugins: fastestmirror
Setting up Remove Process
No Match for argument: php
Loading mirror speeds from cached hostfile
* addons: centos-distro.cavecreek.net
* atomic: www6.atomicorp.com
* base: mirrors.rit.edu
* extras: mirror.nexcess.net
* updates: mirror.umoss.org
addons | 951 B 00:00
atomic | 1.9 kB 00:00
base | 2.1 kB 00:00
extras | 2.1 kB 00:00
updates | 1.9 kB 00:00
Excluding Packages from Plesk Server Administrator
Finished
Package(s) php available, but not installed.
No Packages marked for removal
[root@NSW ~]# php -v
PHP 5.2.14 (cli) (built: Aug 12 2010 15:37:18)
Copyright (c) 1997-2010 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies
with XCache v1.3.0, Copyright (c) 2005-2009, by mOo
but i thing the php 5.2 is still available and not removed
really and great Thanks for Help Mr. littlefrog and already Plesk Panel 10 installed and now working fine.
also all my clients, Domains, Databasess and websites data auto restore back.
thank u so much for appriate Help and now my problem solved.
thanks
ayaz ali
How to run a backup.
make sure you have the disk space to do this but do
1) Download the attached zip
2) Edit db-backup.php script that's attached.
Edit your Plesk password so it can save all your databases.
3) Edit backup.sh
On line 2 edit the date, use VI or PICO whichever you like best.
4) Run the backup
sh /root/backup.sh
Note:
a) This assumes you unzipped your files to /root
If you didn't you will have to update the reference in both files to represent the proper location.
b) I take no responsibility for anything this does or doesn't do. It works for me and that's all that's important to me... use at your own risk.
c) Depending on how much material you have on the server this make take over an hour to run.
  • backup.zip
