problem during installation PLESK 7.5.4 on FC3
S
sofferto
hi i want install plesk 7.5.4 on Fedora Core 3 server.
i execute the psa autoinstaller "psa_installer_v2.0.0_build75050908.11_os_FedoraCore_3_i686" downloaded from sw-soft.com
the system download all necessary package for install but after the download of all packages i have a very long list of this errors:
warning: /root/psa/PSA_7.5.4/FC3_std.updates/lynx-2.8.5-18.i386.rpm: V3 DSA signature: NOKEY, key ID 4F2A6FD2
How i can install Plesk 7.5.4 on FC3 successfully?
Thanks!
Those are actually not errors, they are warnings just as it states. You can simply ignore them.
Although, it would be wise to pay close attention that you do not miss any true errors inbetween those warnings.
I can assist with your installation for a small fee, contact me if you are interested, or need any more assistance, thanks!
Hope this helps! ;)
