problem in login after create subrictation
hesama
Basic Pleskian
hi
im create subrictation in plesk
when login to host recived this error :Error: Authentication failed: invalid username or password specified
username or password is correct
im change username or password is not okey
and delet subrictation and create again is not okey
please help
thanks
just describe in details step-by-step your issue, because we have no such reports from another customers.
im create Subscriptions in plesk
after create can not login to Subscriptions via username pass
im cant to login plesk and cant login to ftp for created Subscriptions
os : windows server2008
plesk : 11.9.35
in my case everything works ok.
We have NO Plesk 11.9.35 (I don't know what you use)
Look, I want to make sure that you perform correct steps. Smthng like that:
- login as admin
- add customer subscription
- logout and logon as customer (use username and pasword, which were specified at "Access to Panel" section) .
I think you use credentials, which were specified at create screen:
Also check users list at your subscription ("Users" tab) and make sure that you have correct user wich has access to Panel.
About FTP - Websites & Domains>FTP access and make sure that all credentials are correct (you may redefine password here)
- login as admin
im chek all is corecct but is not login via ftp and not login to plesk!!
- login as admin
Thanks this can solve my problem
