Problem installing any APS
XavierP
Hi forum,
We have no possibility of install any aps who needs database, here's de log :
cat /var/log/sw-cp-server/error_log
2011-07-04T16:21:56+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user drupal_a0
2011-07-04T16:21:56+02:00 ERR (3): Error de instalación de Drupal en http://domain.es/drupal. Problema
2011-07-04T16:33:44+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user drupal_7
2011-07-04T16:33:44+02:00 ERR (3): Error de instalación de Drupal en http://domain.es/drupal. Problema
2011-07-04T16:37:55+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user joomla_1
2011-07-04T16:37:55+02:00 ERR (3): Error de instalación de joomla en http://domain.es/joomla. Problema
2011-07-04T16:39:01+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user drupal_1a
2011-07-04T16:39:01+02:00 ERR (3): Error de instalación de Drupal en http://domain.es/drupal. Problema
2011-07-04T16:48:31+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user drupal_12
2011-07-04T16:48:31+02:00 ERR (3): Error de instalación de Drupal en http://domain.es/drupal. Problema
2011-07-04T16:50:48+02:00 EMERG (0): APPLY: Step failed 'applySatisfaction'. Failed to create database user drupal_ff
2011-07-04T16:50:48+02:00 ERR (3): Error de instalación de Drupal en http://domain.es/drupal. Problema
As you see there's some issue creating de user in database, but i see these users created in mysql ( i deleted manually ).
I've tryed with admin user and with the customer specific user, but same result.
If i remember well before update 10.1.x i've installed without problems aps like drupal or joomla.
Any idea about that ?
SO : Centos 5.5 Final
kernel : Linux hostname 2.6.38.2-xxxx-std-ipv6-64
Plesk : 10.2
TYA,
XP
Looks like that database was not correctly upgraded during Plesk upgrade procedure. Try to repair it with bootstrapper as it is described in KB article.
Hi there IgorG,
tried to run bootstrapper but fails again, output of /tmp/plesk_10.2.0_installation.log :
===> Restoring database from backup /var/lib/psa/dumps/mysql.preupgrade.10.11.0-10.11.0.20110706-232715.dump.gz
**** Product repair failed.
***** problem report *****
ERROR while trying to execute SQL query, the query was: DELETE FROM mysql.user WHERE user = ''; FLUSH PRIVILEGES;
Check the error reason(see log file: /tmp/plesk_10.2.0_installation.log), fix and try again
STOP Bootstrapper 10.11.0 repair AT Wed Jul 6 23:27:32 CEST 2011
The problem is mysql at where user = "; ?
There the versions of mysql :
mysql.x86_64 5.1.57-3.el5.art installed
mysql-libs.x86_64 5.1.57-3.el5.art installed
mysql-server.x86_64 5.1.57-3.el5.art installed
mysqlclient15.x86_64 5.0.90-1.el5.art installed
php53-mysql.x86_64 5.3.3-1.el5_6.1 installed
Ah !!
I forget to comment this, a message appears when login into phpmyadmin :
Su versión de librería PHP MySQL 5.0.90 es distinta de aquella de su versión de servidor MySQL 5.1.57. Esto puede ocasionar un comportamiento impredecible.
Don't know if related problem, consecuence or maybe other threat ?
As you can see there are packages for different mysql versions. Fix it and run bootstrapper repair again.
I've found there's no possibility to update mysqlclient15 anymore with standart repositories.
Adding the atomicorp repo i noticed a version mysqlclient16-5.1.57-1.el5.art.x86_64.rpm, is the package i need to install ?
And how say to psa that need to use these pkg ?
TYA
