    CentOS2Alma discussion
[PROBLEM] Mysql upgrade to 5 broke my panel
S
scislaghi
Hello,
I'm running plesk 9 under Debian Etch. I've just upgraded my Mysql from 4.0 to 5.0 and now when I try to login into my panel I get this error:
ERROR: PleskFatalException
bad column in table: `backup_time` time NOT NULL default '00:00:00',
0: /opt/psa/admin/plib/common_func.php3:108
psaerror(string 'bad column in table: `backup_time` time NOT NULL default '00:00:00',')
1: /opt/psa/admin/plib/SQLParser.php:128
SQLParser->parseError(string ' `backup_time` time NOT NULL default '00:00:00',')
2: /opt/psa/admin/plib/SQLParser.php:114
SQLParser->_parseLineInTable(string ' `backup_time` time NOT NULL default '00:00:00',')
3: /opt/psa/admin/plib/SQLParser.php:45
SQLParser->parseLine(string ' `backup_time` time NOT NULL default '00:00:00',', integer '16')
4: :
array_walk(array, array)
5: /opt/psa/admin/plib/SQLParser.php:16
SQLParser->getArray(array)
6: /opt/psa/admin/plib/SQLParser.php:23
SQLParser->handleDatabase()
7: /opt/psa/admin/plib/mysql41/mysql41.php:16
mysql41_adopt_database(array, string 'utf8', string 'utf8_general_ci')
8: /opt/psa/admin/plib/mysql41/MySQL41PSADBUpgrader.php:33
MySQL41PSADBUpgrader->run()
9: /opt/psa/admin/plib/mysql41/mysql41_psa.php:17
mysql41_adopt_psa_database(string 'php://stderr', boolean false)
10: /opt/psa/admin/auto_prepend/auth.php3:99
Connecting to ssh and running mysql41upgrade utility produces:
server-02:/opt/psa/bin# ./mysql41upgrade --upgrade
PHP Fatal error: Call to undefined function set_active_button() in /opt/psa/admin/plib/Navigation.php on line 41
Any hint? I'm locked!
Thanks
Stefano
is mysql update the only thing you have done ?
how have you updated, with dotdeb or an other way ?
apt-get install mysql-server-5.0
And I've updated only this one (and its own dependencies as mysql-client-5.0).
Stefano
can you try
apt-get remove psa-backup-manager
apt-get install psa-backup-manager
Done, but without success.....see below
server-02:~# apt-get remove psa-backup-manager
Lettura della lista dei pacchetti in corso... Fatto
Generazione dell'albero delle dipendenze in corso... Fatto
I seguenti pacchetti saranno RIMOSSI:
psa-backup-manager
0 aggiornati, 0 installati, 1 da rimuovere e 40 non aggiornati.
È necessario prendere 0B di archivi.
Dopo l'estrazione, verranno liberati 3912kB di spazio su disco.
Continuare? [S/n] s
(Lettura del database ... 190769 file e directory attualmente installati.)
Rimuovo psa-backup-manager ...
Trying to start service mysql... done
Trying to establish test connection... connected
done
Trying to remove /opt/psa/admin/sbin/backupmng from crontab... done
Trying to clear temporaray database storage... done
server-02:~# /etc/init.d/psa
psa psa-firewall psa-firewall-forward psa-spamassassin
server-02:~# /etc/init.d/psa stop
Stopping Plesk... done
server-02:~# /etc/init.d/psa start
Starting xinetd service... done
Starting bind9 service... done
Starting mysql service... done
Starting postgresql service... not installed
Starting psa-spamassassin service... done
Plesk: Starting Mail Server... already started
Starting Plesk... done
server-02:~# apt-get install psa-backup-manager
I seguenti pacchetti NUOVI (NEW) saranno installati:
psa-backup-manager
0 aggiornati, 1 installati, 0 da rimuovere e 40 non aggiornati.
È necessario prendere 0B/1257kB di archivi.
Dopo l'estrazione, verranno occupati 3912kB di spazio su disco.
Selezionato il pacchetto psa-backup-manager, che non lo era.
(Lettura del database ... 190371 file e directory attualmente installati.)
Spacchetto psa-backup-manager (da .../psa-backup-manager_9.0.0-debian4.0.build90081208.07_i386.deb) ...
Configuro psa-backup-manager (9.0.0-debian4.0.build90081208.07) ...
done
Trying to create temporary database storage... done
Trying to upgrade persistent database storage... done
chown: cannot access `/opt/psa/admin/conf/ssl.crt': No such file or directory
chmod: cannot access `/opt/psa/admin/conf/ssl.crt': No such file or directory
find: /opt/psa/admin/conf/ssl.crt: No such file or directory
server-02:~#
Problem persists.
Stefano
maybe the problem is here:
mmmm... strange, I know, there's a way to regenerate it?
Ste
