    CentOS2Alma discussion
Forwarded to devs Upgrade to 18.0.37 leads to panel error "No entry is registered for key 'translate'"
Hangover2
Regular Pleskian
Username: Hangover2
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
Plesk Obsidian 18.0.36 to 37, Debian 10.10, x86-64
PROBLEM DESCRIPTION
Upgrade to 18.0.37 leads to panel error log "No entry is registered for key 'translate'".
STEPS TO REPRODUCE
Upgrade to Plesk 18.0.37 and check server logs or wait for watchdog summary (if activated).
ACTUAL RESULT
Warning via watchdog:
Code:
[2021-07-26 01:00:01.370] 27739:60fdecf15a761 ERR [panel] No entry is registered for key 'translate':
0: /opt/psa/admin/plib/vendor/plesk/zf1/library/Zend/Registry.php:147
    Zend_Registry::get(string 'translate')
1: /opt/psa/admin/plib/CommonPanel/Validate/Mailname.php:44
    Plesk\CommonPanel\Validate\Mailname->_setupMessageTemplates()
2: /opt/psa/admin/plib/CommonPanel/Validate/Regex.php:20
    CommonPanel_Validate_Regex->__construct(string '/^[\w\-'][\w&\+\-']*(\.[\w&\+\-']+)*$/')
3: /opt/psa/admin/plib/CommonPanel/Validate/Mailname.php:33
    Plesk\CommonPanel\Validate\Mailname->__construct()
4: /opt/psa/admin/plib/AbstractChecker.php:233
    AbstractChecker::email(string '[email protected]')
5: /opt/psa/admin/plib/functions.php:1312
    plesk_mail(array, string 'Watchdog weekly report Jul 18, 2021 - Jul 24, 2021 on xxx.yyy.zzz', string 'Watchdog is running since Jun  2, 2021 12:19 PM.
    Watchdog is monitoring services:
        Plesk Web Ser...', boolean false, string '[email protected]')
6: /opt/psa/libexec/modules/watchdog/cp/send-report:108
ERROR: Zend_Exception: No entry is registered for key 'translate' (Registry.php:147)
EXPECTED RESULT
no error
ANY ADDITIONAL INFORMATION
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
Thank you for the report. Could you please provide logs:
  • /var/log/plesk/modules/wdcollect.log
  • /var/log/plesk/install/autoinstaller3.log
  • /var/log/plesk/panel.log
Panel.log before and after the error-time:
Code:
[2021-07-26 00:00:07.093] 25512:60fddee7143eb ERR [panel] Unable to get key: Repository is not opened
[2021-07-26 01:00:01.371] 27739:60fdecf15a761 ERR [panel] No entry is registered for key 'translate'
[2021-07-26 03:31:44.009] 9172:60fe10800259a ERR [panel.ui] URL "/index.php?s=/Index/\think\app/invokefunction&function=call_user_func_array&vars[0]=md5&vars[1][]=HelloThinkPHP21" is invalid
wdcollect.log before and after the error-time:
empty (latest log is Jul 23 06:57:33)
autoinstaller3.log wdcollect.log before and after the error-time:
Code:
[2021-07-25 15:29:47.368723] Component plesk/composer: mode up2date,  installed_buildtime=0,  available_buildtime=0
[2021-07-25 15:29:47.368765] Component plesk/monitoring: mode up2date,  installed_buildtime=0,  available_buildtime=0
[2021-07-26 06:25:01.647820] Environment locale name is 'en_US.UTF-8'
[2021-07-26 06:25:01.648388]
Plesk Installer 3.37.0 (revision 5a661e1ff3fa) started at (timezone CET) Mon Jul 26 06:25:01 2021
Command line arguments: /opt/psa/admin/bin/autoinstaller --select-product-id plesk --select-release-current --show-upgradable-components --enable-xml-output
[2021-07-26 06:25:01.648409] SourceUrl: original source url is http://autoinstall.plesk.com/
I'm experiencing the same issue.
What is the best way to submit the logs? I don't want to post them here, where they can be read by the public.
The Upgrade to 18.0.39 does not solve the problem.
I still got:
i can not use the repair utility because the htaccess query does not accept my credentials and comes up again.
If i start plesk repair -y via CLI the output is:
exit status 3
Thanks for any help
