- Server operating system version
- Debian 10.13
- Plesk version and microupdate number
- Plesk 18.0.46
Hello,
I’ve upgraded my server to Debian 10.13, then I’ve upgraded Plesk to 18.0.46. Since then I have two problems :
1) I can’t receive mails from the server. I get a « Connexion to default ports of the mail server expired » from my mail client. I’ve checked the services, and Postfix, Dovecot and SMTP are running. Firewalld doesn't seem to be installed. firewall-cmd doesn't exist. Plesk firewall is active.
2) Roundcube is not working. I had to reinstall it, but the installation process ends with this message :
Preparing to unpack .../plesk-roundcube_1.5.3-v.debian.10+p18.0.46.1+t220905.1648_all.deb ...
Unpacking plesk-roundcube (1.5.3-v.debian.10+p18.0.46.1+t220905.1648) ...
Setting up plesk-roundcube (1.5.3-v.debian.10+p18.0.46.1+t220905.1648) ...
Installing new version of config file /etc/apache2/plesk.conf.d/roundcube.htaccess.inc ...
Installing new version of config file /etc/psa-webmail/roundcube/roundcube.conf ...
Installing new version of config file /usr/share/psa-roundcube/config/mimetypes.php ...
Installing new version of config file /usr/share/psa-roundcube/plugins/managesieve/config.inc.php ...
Installing new version of config file /usr/share/psa-roundcube/plugins/markasjunk/config.inc.php ...
Trying to upgrade Roundcube Web Based mail client configs and DB from '1.4.13' to '1.5.3'... Executing database schema update.
Updating database schema (2020020101)... [FAILED]
ERROR: Error in DDL upgrade 2020020101: [1091] Can't DROP 'user_id_fk_cache'; check that column/key exists
Warning: upgrade Roundcube Web Based mail client configs and DB from '1.4.13' to '1.5.3'. Run /usr/share/psa-roundcube/bin/update.sh manually to complete upgrade.
***** installing problem report *****
STOP plesk-roundcube-1.5.3 installing AT Thu Sep 22 23:05:32 CEST 2022: PROBLEMS FOUND
Lancement des contrôles composants et produits...
Téléchargement du fichier report-update: 0%
Téléchargement du fichier report-update: 100% a été terminé.
Téléchargement du fichier pool/PSA_18.0.46_9656/examiners/py_launcher.sh: 0%
Téléchargement du fichier pool/PSA_18.0.46_9656/examiners/py_launcher.sh: 100% a été terminé.
When I try to run the "/usr/share/psa-roundcube/bin/update.sh" command, I get "/usr/bin/env: ‘php’: No such file or directory".
Thank you
Thank you
