Problem with apache
bokken
Basic Pleskian
Hello, i having problems starting apache, im getting this error.
# /etc/init.d/httpd start
Starting httpd: httpd: Syntax error on line 210 of /etc/httpd/conf/httpd.conf: Syntax error on line 6 of /etc/httpd/conf.d/zz010_psa_httpd.conf: Syntax error on line 10 of /usr/local/psa/admin/conf/generated/13540196600.18644200_horde.include: Syntax error on line 31 of /usr/local/psa/admin/conf/webmail_horde_bootstrap.conf: Could not open configuration file /usr/local/psa/admin/conf/generated/13539939590.34363900_recaudalia_com_webmail.include: No such file or directory
[FAILED]
I tryed to repair the apache templates:
# /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
PleskUtilException: '/usr/local/psa/admin/bin/apache-config' '-t' failed with code .
stdout:
stderr:
file: /usr/local/psa/admin/plib/Service/Agent/Transport/Local/Exec.php
line: 71
code: 0
trace: #0 /usr/local/psa/admin/plib/Service/Agent/Transport/Local.php(58): Service_Agent_Transport_Local_Exec->process(4, Object(Service_Agent_Command_Exec), Object(Service_Agent_Log), Object(Service_Agent_Transport_LocalTransaction))
#1 /usr/local/psa/admin/plib/Service/Agent/Transport/Local.php(24): Service_Agent_Transport_Local->_command(4, Object(Service_Agent_Command_Exec), Object(Service_Agent_Transport_LocalTransaction), Object(Service_Agent_Log))
#2 /usr/local/psa/admin/plib/Service/Agent.php(133): Service_Agent_Transport_Local->process('e2c306114d76a7f...', Array, Object(Service_Agent_Log))
#3 /usr/local/psa/admin/plib/Template/Writer/Apache.php(58): Service_Agent->commit()
#4 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(196): Template_Writer_Apache->test()
#5 /usr/local/psa/admin/plib/Template/Configuration/Applier.php(117): Template_Configuration_Applier->_applyConfigurationsToServiceNode(1, Array)
#6 /usr/local/psa/admin/plib/WebServerManager/Adapter/Apache.php(125): Template_Configuration_Applier->applyConfiguration(true)
#7 /usr/local/psa/admin/plib/WebServerManager/Adapter/Apache.php(313): WebServerManager_Adapter_Apache->sync()
#8 /usr/local/psa/admin/plib/WebServerManager.php(199): WebServerManager_Adapter_Apache->reconfigureServer(Object(Db_Table_Row_ServiceNode))
#9 /usr/local/psa/admin/plib/api-common/Httpdmng.php(123): WebServerManager->reconfServer()
#10 /usr/local/psa/admin/sbin/httpdmng(13): Httpdmng->__construct()
#11 {main}
2012-11-27T13:34:21+01:00 ERR (3): Apache config (13540196600.18644200) generation failed: httpd: Syntax error on line 210 of /etc/httpd/conf/httpd.conf: Syntax error on line 6 of /etc/httpd/conf.d/zz010_psa_httpd.conf: Syntax error on line 10 of /usr/local/psa/admin/conf/generated/13540196600.18644200_horde.include: Syntax error on line 31 of /usr/local/psa/admin/conf/webmail_horde_bootstrap.conf: Could not open configuration file /usr/local/psa/admin/conf/generated/13539939590.34363900_recaudalia_com_webmail.include: No such file or directory
PleskUtilException: /usr/local/psa/admin/bin/httpdmng '--reconfigure-server' '-no-restart' failed with message: Empty error message from utility.
file: /usr/local/psa/admin/plib/common_func.php3
line: 1065
code: 0
trace: #0 /usr/local/psa/admin/plib/common_func.php3(983): util_exec('httpdmng', Array, Array, 'msg', NULL)
#1 /usr/local/psa/admin/plib/Os.php(17): smart_exec('httpdmng', Array, Array, 'msg')
#2 /usr/local/psa/admin/plib/Os.php(28): Os::exec('httpdmng', Array, 'msg')
#3 /usr/local/psa/admin/plib/api-common/Httpdmng.php(89): Os::execEx('httpdmng', Array)
#4 /usr/local/psa/admin/sbin/httpdmng(13): Httpdmng->__construct()
#5 {main}
Execution failed.
Command: httpdmng
Arguments: Array
[0] => --reconfigure-server
[1] => -no-restart
Details: Empty error message from utility.
This its a big problem, no webserver working.
What its the problem?
Try to switch webmail status for the domain and reconfigure all configs again. Or switch webmail to another if not help. Possible you encountered some db inconsistency.
After
the error
httpd: Syntax error on line 210 of /etc/httpd/conf/httpd.conf: Syntax error on line 6 of /etc/httpd/conf.d/zz010_psa_httpd.conf: Syntax error on line 10 of /usr/local/psa/admin/conf/generated/13540196600.18644200_horde.include: Syntax error on line 31 of /usr/local/psa/admin/conf/webmail_horde_bootstrap.conf: Could not open configuration file /usr/local/psa/admin/conf/generated/13539939590.34363900_recaudalia_com_webmail.includ e: No such file or directory
reproduced?
And whe space character in the error "includ e" is not misprint on the forum?
Try to remove this config from /usr/local/psa/admin/conf/webmail_horde_bootstrap.conf manually and regenerate configs again:
