Issue Problem with applying changes to DNS records
Thanks for the confirmation. Please execute the command from my previous reply corresponding to your OS. If you get the same output as before then the main.css file is modified again. If you haven't done it manually, this will indicate that some other process does (possibly malicious). However, this must be further investigated by our team. I would suggest opening a ticket with Plesk support. To sign-in to support and open a ticket go to
If you got your license from a reseller, your reseller is responsible for providing support. They can escalate the request to our team on your behalf. If the reseller does not provide support, here is an alternative to get support directly from Plesk:
It seems that this has reared its head again. I am using
Web Host Edition
I am having the issue where I add a DNS entry and its not coming up with the apply banner at the top of the page. Any help with this? I have changed the main.css file and this has not fixed it either. I have also tried several browsers.
