Problem with CGI + Openbase_dir
VinMhas
Since I've installed the last update, then i've got a problem with the OpenBase_dir directive of PHP.
For example I've got three domains on my Plesk 11.0.9-server. All domains are configured with CGI.
If i change the Openbase_dir directive on domain 1, then it also changes for example domain3 among others..
This results in a broken website. If i visit domain3 i receive the following error-message:
Warning: require(): open_basedir restriction in effect. File(/var/www/vhosts/domain3.com/httpdocs/wp-blog-header.php) is not within the allowed path(s): (/var/www/vhosts/domain1.com/:/tmp/) in /var/www/vhosts/domain3.com/httpdocs/index.php on line 17 Warning: require(/var/www/vhosts/domain3.com/httpdocs/wp-blog-header.php): failed to open stream: Operation not permitted in /var/www/vhosts/domain3.com/httpdocs/index.php on line 17 Warning: require(): open_basedir restriction in effect. File(/var/www/vhosts/domain3.com/httpdocs/wp-blog-header.php) is not within the allowed path(s): (/var/www/vhosts/domain1.com/:/tmp/) in /var/www/vhosts/domain3.com/httpdocs/index.php on line 17 Warning: require(/var/www/vhosts/domain3.com/httpdocs/wp-blog-header.php): failed to open stream: Operation not permitted in /var/www/vhosts/domain3.com/httpdocs/index.php on line 17 Fatal error: require(): Failed opening required './wp-blog-header.php' (include_path='.:') in /var/www/vhosts/domain3.com/httpdocs/index.php on line 17
If I configure all the domain as a Apache-module, then the problem doesn't happen.
What's wrong?
How are you changing that openbase dir? As far as I know, each of domain have its own php settings for this, so I'm not sure how they connect? Are you going that under Websites & Domains -> scroll down and click on domain name -> PHP Settings tab -> openbase dir
That's correct! If i set a openbase_dir restriction ( let's say: [docroot:/:tmp/] or or [webspaceroot]/:[tmp:/] ) then this will affect other domains as well. Could this be a bug in 11.0.9?
To clarify: i set the openbase_dir for domain1 at [webspaceroot]/:[tmp:/] ( that would be /var/www/vhosts/domain.com/httpdocs ). If i do so, then the same restriction applies for other domain.
If i visit domain2 through my webbrowser, then i receive a message an openbase error. Domain2 can only access files in Domain1.
It seems that the openbase_dir has a global effect on the server.
Of course it has, since all domains are in same subscription. Try to put absolute path like /var/www/vhost/domain.com/httpdocs/your directories
