Problem with connecting trough IMAP
FelixB
Basic Pleskian
Hello there,
i've updated my Server to Plesk 10.x
now every time when i try to connect with imap i can't, in the server log /var/log/syslog i find:
alpha postfix/smtpd[20413]: warning: xxx-xxx-xxx-xxx.dynamic.hispeed.ch[xxx.xxx.xxx.xxx]: SASL PLAIN authentication failed:
what is wrong?
Hi IgorG,
thank you for the answer, but...
The problem is caused by SQLite3 of version <= 3.2.x.
You should upgrade SQLite3 to version 3.3.0 or higher to resolve the problem.
The problem persists for Parallels Plesk Panel 9.0.0 and will be fixed in next patch.
I've Version SQLite 3.7.3
And Plesk 10.4.4
