    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Question Problem with HTTPS connection
kubak
AlmaLinux 8
Version 18.0.45 Update #2
I have a problem with connecting with HTTPS hosts.
I have default settings in plesk. iptables is not installed.
Code:
[root@ns3221495 conf]# iptables -v
-bash: iptables: command not found
I also use fail2ban and server IP is added to "Trusted IP Addresses"
Log (first host, api soap wsdl DPD Courier) :
Code:
[root@ns3221495 conf]# curl -v https://dpdservices.dpd.com.pl/DPDPackageXmlServicesService/DPDPackageXmlServices?wsdl
*   Trying 91.209.152.36...
* TCP_NODELAY set
* connect to 91.209.152.36 port 443 failed: Connection timed out
* Failed to connect to dpdservices.dpd.com.pl port 443: Connection timed out
* Closing connection 0
curl: (7) Failed to connect to dpdservices.dpd.com.pl port 443: Connection timed out
Example with another important host for me:
Code:
[root@ns3221495 conf]# curl -v https://api-shipx-pl.easypack24.net/v1/
*   Trying 91.216.25.164...
* TCP_NODELAY set
* connect to 91.216.25.164 port 443 failed: Connection timed out
* Failed to connect to api-shipx-pl.easypack24.net port 443: Connection timed out
curl: (7) Failed to connect to api-shipx-pl.easypack24.net port 443: Connection timed out
Thanks for any suggestions and help!
Please check the output of commands:
# traceroute -T -p 443 dpdservices.dpd.com.pl
# traceroute -T -p 443 api-shipx-pl.easypack24.net
Depending on the results of the traceroute command, the connection can be blocked on the server itself or on the intermediate firewall.
