Hello,
i have install spamassine one Plesk 12.5 and i got an error. Then i remove spamassassine and i got the same error.
Anyone a idear what i can do to fix this? (System: Ubuntu 14.04, Plesk 12.5.30)
Code:
[2016-07-20 03:57:52.743250] Installation started in background
[2016-07-20 03:57:52.743328]
Getting bootstrapper packages to installation list:
[2016-07-20 03:57:52.743379] Following bootstrapper packages will be installed: (empty)
[2016-07-20 03:57:52.743400] ----------------
[2016-07-20 03:57:52.743415] Getting packages to installation list:
[2016-07-20 03:57:52.743449] Following packages will be installed: dummy_obsoleter_psa-spamassassin-0.0
[2016-07-20 03:57:52.743482] ----------------
[2016-07-20 03:57:52.743540] Auflösung der Paketabhängigkeiten wird geprüft.
[2016-07-20 03:57:52.743593] autoinstaller: read output of DEBIAN_FRONTEND=noninteractive LANG=C apt-get --assume-yes --show-upgraded --purge --no-reinstall -o APT::Get::List-Cleanup=true -o Dpkg::options::=--force-confdef -o Dpkg::options::=--force-confold -o APT::Get::AllowUnauthenticated=false -o Acquire::Retries=3 -t 'trusty*' --just-print install psa-spamassassin-
[2016-07-20 03:57:53.524067] add to install list sa-compile-3.4.0-1ubuntu2.1
[2016-07-20 03:57:53.644709] Check package set before installation
[2016-07-20 03:57:53.645069] The following packages from not selected components will be installed because they are required by other components' packages you selected for installation:
[2016-07-20 03:57:53.645173] Pakete werden installiert
[2016-07-20 03:57:53.648988] Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_12_5_30', sequence='prep', stage='execute', sequence_order='-1', operation='install', exec_cmd='touch /tmp/pp-bootstrapper-mode.flag; touch /var/lock/parallels-panel-maintenance-mode.flag; rm -f /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', output: ~empty
[2016-07-20 03:57:53.669423] Reading package lists...
Building dependency tree...
Reading state information...
sa-compile is already the newest version.
The following packages will be REMOVED:
psa-spamassassin*
0 upgraded, 0 newly installed, 1 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 310 kB disk space will be freed.
(Reading database ... 113595 files and directories currently installed.)
Removing psa-spamassassin (12.5.30-ubuntu14.04.build1205150826.19) ...
invoke-rc.d: initscript spamassassin, action "status" failed.
Purging configuration files for psa-spamassassin (12.5.30-ubuntu14.04.build1205150826.19) ...
Setting up sa-compile (3.4.0-1ubuntu2.1) ...
Running sa-compile (may take a long time)
cc: internal compiler error: Bus error (program as)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.8/README.Bugs> for instructions.
make: *** [body_0.o] Error 4
command 'make >>/tmp/.spamassassin10111hO0aDUtmp/log' failed: exit 2
dpkg: error processing package sa-compile (--configure):
subprocess installed post-installation script returned error exit status 25
Errors were encountered while processing:
sa-compile
E: Sub-process /usr/bin/dpkg returned an error code (1)
Bootstrapper has finished action (exec time: 0 sec.): parent_name='PLESK_12_5_30', sequence='pkgs', stage='rollback', sequence_order='1', operation='install', exec_cmd='rm -f /tmp/pp-bootstrapper-mode.flag; rm -f /var/lock/parallels-panel-maintenance-mode.flag; touch /var/lock/parallels-panel-upgrade-failure.flag; :'', m_arch='', output: ~empty
[2016-07-20 03:58:04.547888] Error: Ein Fehler ist aufgetreten bei dem Versuch, Pakete zu installieren.
Achtung! Ihre Software ist vielleicht nicht betriebsbereit.
Bitte kontaktieren Sie den technischen Produktsupport.
