Problem with MSSQL WebAdmin on Plesk Panel 11.5
Status
Not open for further replies.
Andrei C
Regular Pleskian
Dear Support,
When I try to use webadmin, I see next error:
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /mssql/app/connect.aspx
I try to use next command, to fix:
"%plesk_cli%\repair.exe" --reconfigure-mssql-webadmin-site
But I have the same problem. How can I fix this?
Status
