Question Problem with multiple IP-Addresses and SSL
A
adamjohnson
Hi there,
I'm quite new to all of this, so please be patient ;)
I've just set up a new Ubuntu 14.04 Server with Plesk 12 (hosted by Strato) and added a second IP-Address.
In this case, the primary IP-Address is: 12.345.678.901
The Server is running with nginx reverse proxy activated. Now when it comes to ssl encryption for my domains, all domains on the second IP work as expected. But if I try to access any domain on the primary IP (doesn't matter if the domain is protected by a bought certificate or a self signed) the browser throws the error ERR_CONNECTION_CLOSED and the nginx log says the following:
[error] 4327#0: *8 no "ssl_certificate" is defined in server listening on SSL port while SSL handshaking, client: 123.456.789.012, server: 12.345.678.901:443
There's no entry in the apache log-files for that event.
If I switch the domain to the other IP everything is working as expected.
What can I do to fix this and why does this error appear?
Thank you in advance.
Best Regards
