Resolved Problem with node start
Qusay
Basic Pleskian
Debian 10
18.0.51
I have this problem
to started this app
and all thing it's fine
just that give me
[21:23:12] Error: EACCES: permission denied, unlink '/var/www/vhosts/golden-squad.com/donate.golden-squad.com/dist/themes/default/subscription.ejs'
at Object.unlinkSync (node:fs:1808:3)
at Function.rimrafSync [as sync] (/var/www/vhosts/golden-squad.com/donate.golden-squad.com/node_modules/rimraf/rimraf.js:303:17)
at file:///var/www/vhosts/golden-squad.com/donate.golden-squad.com/node_modules/del/index.js:130:11
at Array.map (<anonymous>)
at deleteSync (file:///var/www/vhosts/golden-squad.com/donate.golden-squad.com/node_modules/del/index.js:122:29)
at clean (file:///var/www/vhosts/golden-squad.com/donate.golden-squad.com/gulpfile.mjs:19:12)
at bound (node:domain:433:15)
at runBound (node:domain:444:12)
at asyncRunner (/var/www/vhosts/golden-squad.com/donate.golden-squad.com/node_modules/async-done/index.js:55:18)
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
[21:23:12] 'default' errored after 38 ms
Screenshot 2023-04-02 at 22-23-19 Node.js on donate.golden-squad.com - Plesk Obsidian 18.0.51.png
It states right there that you don't have permission. Make sure the file has the correct permissions set and is set for the user's system account for the files and folders.
What are permissions and ownerships of /var/www/vhosts/golden-squad.com/donate.golden-squad.com/dist/themes/default/subscription.ejs?
# ll /var/www/vhosts/golden-squad.com/donate.golden-squad.com/dist/themes/default/subscription.ejs
Let's try again. Please post the output of
if i use ssh its work fine with out any problem this problem if i using app in panel
We still have not seen ownership and group of the file ...
sorry permission file its 644
error
[01:53:29] Error: EACCES: permission denied, unlink '/var/www/vhosts/golden-squad.com/donate.golden-squad.com/dist/themes/default/subscription.ejs'
[01:53:29] 'default' errored after 36 ms
in file
Code:
<%- include('partials/header.ejs') %>
<div class="container">
    <div class="row info">
        <div class="col s12">
            <h3>
                <%= translate('SUBSCRIPTION_TITLE') %>
            </h3>
            <p>
                <%= translate('SUBSCRIPTION_DESCRIPTION') %>
            </p>
        </div>
    </div>
    <div class="row">
        <div class="col s12 m12 l12">
            <div class="card subscription">
                <div class="card-content">
                    <span class="card-title"><%= translate('SUBSCRIPTION_DETAILS_TITLE') %></span>
                    <% if (subscription.state === 'PENDING') { %>
                        <div class="pending"><%= translate('SUBSCRIPTION_DETAILS_STATUS_PENDING_DESCRIPTION') %></div>
                    <div class="details">
                        <div><%= translate('SUBSCRIPTION_DETAILS_STATUS') %></div>
                        <div>
                                <span class="pending"><%= translate('SUBSCRIPTION_DETAILS_STATUS_PENDING') %></span>
                            <% } else if (subscription.state === 'ACTIVE') { %>
                                <span class="active"><%= translate('SUBSCRIPTION_DETAILS_STATUS_ACTIVE') %></span>
                            <% } else { %>
                                <span class="cancelled"><%= translate('SUBSCRIPTION_DETAILS_STATUS_CANCELLED') %></span>
                        </div>
                        <div><%= translate('SUBSCRIPTION_DETAILS_PACKAGE_NAME') %></div>
                        <div>
                            <%= plan.basePackage.name %>
                        </div>
                        <div><%= translate('SUBSCRIPTION_DETAILS_PACKAGE_PRICE') %></div>
                        <div>
                            <%= plan.basePackage.price.currency %> <%= plan.basePackage.price.amount %>
                        </div>
                        <div><%= translate('SUBSCRIPTION_DETAILS_CYCLE') %></div>
                        <div>
                            <%= plan.basePackage.subscription %>
                        </div>
                    </div>
                </div>
                <div class="card-action">
                    <% if (subscription.state === 'PENDING' && locals.pending) { %>
                        <a href="<%= locals.pending.approvalLink %>" class="btn waves-effect waves-light">
                            <%= translate('SUBSCRIPTION_APPROVE') %>
                        </a>
                    <% if (subscription.state === 'ACTIVE' || subscription.state === 'PENDING') { %>
                        <form method="post" class="inline">
                            <input type="hidden" name="_csrf" value="<%= csrfToken %>">
                            <button class="btn waves-effect waves-light" name="cancel" type="submit">
                                <%= translate('SUBSCRIPTION_CANCEL') %>
                            </button>
                        </form>
                </div>
            </div>
            <div class="card subscription-history">
                    <span class="card-title"><%= translate('SUBSCRIPTION_HISTORY_TITLE') %></span>
                        <% history.forEach(function (h) { %>
                            <div><%= h.created %></div>
                            <div><%= h.payment.transactionId %></div>
                    </div>
                </div>
            </div>
        </div>
    </div>
</div>
<%- include('partials/footer.ejs') %>
I don't think you're understanding...
In your SSH session, issue the following command:
Bash:
Provide the output of what that gives you.
Bash:
root@golden-squad:~# ll /var/www/vhosts/
-bash: ll: command not found
-rw-r--r-- 1 golden-squad.com_eshfo515q8
j psacln 3798 Apr 5 03:22 /var/www/vhos
One cause could be that the file may need group write permissions, because the unlink is not a read-only operation. So changing permissions to at least 664 instead of 644 could help. Personally I'd just try 755 to rule such things out. Could you try that please?
im try
664
755
and
764
seem problem
Is that file the only file in that directory and can the path be walked with correct permissions? It could be thinkable that the file itself has correct permissions, but a directory upwards does not. And finally an idea could be to remove the fully qualified path starting at the server root and to replace it with a relative path that starts (without slash /) where the app is rooted.
Code:
total 48
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln 1453 Apr  5 03:22 account.ejs
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln  902 Apr  5 03:22 error.ejs
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln  824 Apr  5 03:22 login.ejs
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln  843 Apr  5 03:22 login_error.ejs
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln 2032 Apr  5 03:22 missing_steam_connection.ejs
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln 2054 Apr  5 03:22 order-overview.ejs
drwxr-xr-x 2 root                         root   4096 Apr  7 14:51 partials
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln  935 Apr  5 03:22 payment_steam_mismatch.ejs
drwxr-xr-x 3 root                         root   4096 Apr  7 14:51 payments
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln  312 Apr  5 03:22 privacy-policy.ejs
drwxr-xr-x 2 root                         root   4096 Apr  7 14:51 steps
-rw-r--r-- 1 golden-squad.com_eshfo515q8j psacln 3798 Apr  5 03:22 subscription.ejs
You have to clean up the ownership of the files and folders so every file and folder has the golden-squad.com_eshfo515q8j:psacln rights. Otherwise, you get stuck in this trial-and-error mode.
Correcting the ownership can be done with this command:
Code:
# plesk repair fs donate.golden-squad.com -v
Code:
@maartenv good idea, probably also needed for the upper directories as the lower ones are root-owned ...
its now fixed thanks
but needed one more help
i want anyone open this url like
to open app
with out show any port for client
so if hey now a port
example
they sent it him to
https://ex.example.com
how can i do this please
